- Joined
- 14 Jul 2011
- Messages
- 20,287
Well the UIC and the Swedish railways have been pushing a low cost development of the ERTMS system for use on secondary routes with relatively low traffic levels which uses the equipment on a train designed for a conventional ERTMS implementation.
It effectively implements the signalling topology of the Level 3 proposals but does so without moving blocks, allowing to be implemented far more cheaply as there is far less work to do to produce an operational real-world system.
It allows the removal of the all trackside signals and almost all track circuitry, leaving axle counters or track circuits only in a limited set of locations and allowing the elimination of all signal wiring in favour of radio based communications systems.
They claim that this can reduce signal maintenance costs by upwards of 50%, which could have implications for the viability of various branch lines, especially ones that are currently operated by relatively self contained fleets of vehicles or where RETB is currently installed (and is nearing retirement).
So has anything been done by Network Rail in attempting to participate in this development programme, especially now the Cambrian Line ERTMS Level 2 appears to be functioning reasonably well?
