Entire 800/801/802 fleet stood down for safety checks
kez19
15 May 2020
Dundee
LNER's intercity bi-modes ARE Azumas. Their only other trains are electric-only
I thought intercity acted similar? As when they were operating up here it did the same thing, ie diesel to Haymarket switched to electric onwards then in reverse?
They run two types of train to Scotland, class 800 bimode and class 801 electric - they look just the same, but the latter can’t run beyond Edinburgh. Unless you get into the real detail, they all look identical to passengers…
23 Nov 2015
I have no idea what you are talking about.
crablab
8 Feb 2020
We are continuing to work together to begin the return of Azuma trains into service from next week.
Back to referring to them as "Azuma" today and not "Class 800 Hitachi", as in yesterday's video from David Horne.
How confusing.
I think gaffer tape might not withstand high speed airflow!
Engineer taping up an easyJet engine cowl - from Internet Flight Community but as it's been round the Internet a million times who knows who took it?
To be fair it's "speed tape" which is £100+ a roll!
Starmill
18 May 2012
Bolton
So where are the Intercity trains?
The family of trains were originally known by their project name Intercity Express Programme or IEP before there was anything else to call them. After Hitachi won the work with their A Train product, (derived from the now-famous aluminium of the body) they were known as AT300 Super Express Train for a time. They are now known by many different names which they've been given by their operators:
Nova 1 at TransPennine Express
Azuma at LNER
Intercity Express Train or IET at GWR
Paragon at Hull Trains
Aurora at EMR
43096
23 Nov 2015
Azuma at LNER
Aurora at EMR
Or Super Hitachi Intercity Trains by some staff and enthusiasts. Yes, there’s an acronym, which seems more appropriate than ever.
I don't recognize this statement from Andrew Adonis about the Azuma introduction on the ECML:
"They [NR] had 10 years to get these signalling issues right," he said. "They'll be much more expensive to operate, they'll be slower, they'll have less capacity and hundreds of millions of pounds of public money has been wasted again.”
I think he was actually referring to the GW electrification truncation and the consequent need to order more bi-modes for GWR instead of cheaper electric-only sets.
That pararagraph you’ve quoted does seem to run together in the article, but I reckon it should be broken down into two completely unrelated problem areas. There were trackside interference issues on the ECML, I think at the time it was explained that some signalling equipment didn’t meet NR’s published electrical noise tolerance - so they altered the trains to solve a problem on the track. We had a thread about it, and funnily enough Adonis was quoted making the same “NR had 10 years” point:
But that seems totally unrelated to the effect of GWML wiring decisions. And I also don’t think it’s possible to describe the overall ECML fleet numbers as causing a capacity issue, they basically got an equivalent 9 car fleet and many extra 5 cars. (Give or take a couple of units.)
Grumpy Git
13 Oct 2019
A frequent complaint in Ian Walmsley's column in Modern Railways - rolling stock engineers being made to solve problems created by others.
Again I can sympathise with this argument.
I'm continually asked to make equipment work outside its design parameters because someone with no experience has designed another product out of specification.
In an extreme case, imagine someone building a train with an incorrect wheel gauge, and the solution being to alter all the track (and all the other trains)!
BayPaul
11 Jul 2019
If you are referring to the Intercity 125 class trains, otherwise known as HST, these trains are diesels, not bi-modes. LNER disposed of their fleet in 2019. Many have been scrapped, but Scotrail and GWR both run fleets of shortened HST trains on their own services, Cross Country have a few for their services, and East Midlands Trains are about to take their last few out of service (or may have just done so). Chances are, if you use a Scotrail service from North of Edinburgh to connect into an LNER service south of Edinburgh you will go on one of the Scotrail HSTs.
None of LNER's crew are still competent on the HSTs, and the out of service ones are not compliant with current legislation, so it is not a simple short-term solution to just bring some back in to service on the routes - a good comparison would be how difficult it would be now for British Airways to re-introduce Boeing 747s.
aar0
13 Sep 2016
I'd have thought Paddington to Cardiff would be a more sensible use of what are very limited resources, with TFW handling the connections for stations to Swansea.
There's a IET Depot in Swansea, almost within sight of the station. Contractually I believe (not that it matters with so few trains!) that GWR have to run Swansea-London, and their Cardiff-Londons are extras.
Failed Unit
26 Jan 2009
Central Belt
Looking at the announcement today - still nothing to get excited about if you are on LNER. (On a Bi-mode route)
The timetable for tomorrow loaded. Nothing much that needs to be a Bi-Mode (the Leeds - Aberdeen service which is terminating at Edinburgh) - All other Bi-Mode trains cancelled.
See what Saturday brings, but at the very minimum nothing from North of Edinburgh as the stock didn't make it there on Friday evening (unless of course they already have trains in Aberdeen and / or Inverness)
fgwrich
15 Apr 2009
Hampshire
Telegraph report doesn't make much sense does it... HST carriages are not much use without the locos !
The 387 run down to Parkway seems to have gone well. Timing looks very close to what some 800 services achieve.
It’s funny, because the article they produced yesterday was excellent and really told the IEP program how it is (Insanely Expensive Project). This article seems to contradict itself and is frankly, gash.
