Entire 800/801/802 fleet stood down for safety checks
AdamWW
6 Nov 2012
If a similar problem had been discovered with Mk3 coaches 10 years ago, the effect would have been even worse. The benefits of multiple operators using the same class far outweigh the potential drawbacks.
Although as has been pointed out above, with an 800 it just takes a problem with one coach to put up to 9 coaches out of service even if 8 of them are completely fine.
With HSTs or Mk 3 loco hauled trains you'd just live without that coach.
Of course even if the government had insisted on splitting their order into two different types of train to protect against events like this, how would they guarantee that two fleets built to the same specs at a similar time wouldn't suffer from similar problems? Would they have to insist that there were no suppliers of parts and materials in common?
I think if you were going to extreme lengths to avoid something like this, the only practical way would have been to renew half the fleet early enough, wait a decent length of time, then deal with the other half.
HamworthyGoods
15 Jan 2019
With the current situation you'd still have to check all of them, and if it affected the power car the outcome would be the same.
CBlue
30 Mar 2020
East Angular
With loco hauled trains it just takes a loco failure to knock the whole thing out of action.
This feels somewhat like bibble over wanting everything to be "proper trains" and therefore loco hauled?
Only if you use non-standard locos like 68+Mk5. If the locos are standard then you just use a different one.
They do have a certain flexibility advantage.
BayPaul
11 Jul 2019
Putting reliance on only one type of device to cover an essential service puts any system at serious risk of Common-Mode Failure. So having ALL your trains from one class might seem attractive to the accountants but it leaves an operator wide open to one fault causing no trains, and here it’s happened.
The oft quoted withdrawal of the Bullied MN class steam locos due to crank axle failures was one of these common mode failures, as was the total suspension of the new AC electrics on Clydeside in the early 60s When transformers started failing. However the MNs weren’t the only class and substitutes were drafted in, and the Clydeside services were put back into steam working until the issue had been engineered away.
GWR & LNER don’t appear to have any backup, so it’s accountants 1 (og) engineering 0.
It is also worth saying that if the fleet was split in half, the impact of a major event like this would be halved, but the average frequency would be doubled, as there are twice the number of different parts to go wrong. Say a typical class needs the whole fleet withdrawn once every 20 years due to an issue like this. With a uniform fleet, you get one massive period of disruption, then 20 years of good running. With two fleets you would get periods of (lesser but still severe) disruption every 10 years. So you don't gain much benefit from disruption reduction, and still have all of the operational and financial challenges.
Fudgefrog
10 Feb 2009
Then what you’re describing isn’t an issue of common design, but preferring fixed unit designs that can’t easily be short formed. But even then, you assume that there weren’t circumstances in which, say, the whole HST fleet could be grounded - problems with wiring or AC units, unsafe couplers, a flawed brakes design etc. could easily have grounded an entire fleet pending fixes.
This is an unfortunate blip in what has arguably been a successful roll out of a brand new train type, that has delivered considerably savings and performance upgrades over the older BR stock (whatever one’s thoughts might be about seats, onboard ambience etc.). British-built Electrostars were grounded after it was discovered the power supply was too poor for them to operate. Heathrow Express/Connect had to move to skeleton services after major corrosion was discovered in their Class 332 fleet. Boeing 787s and 737-MAX aircraft both had to be grounded because of design flaws. These things happen, the question in my mind is more how efficiently and responsibly Hitachi, the TOCs and others involved will move to fix or alleviate the problem.
43096
23 Nov 2015
Considerable savings? The IEP project was exceptionally poor value for money and is massively inflating costs for the operators forced to use them.
73128
8 Dec 2019
Reading
Still not including SWR, despite the routes west of Salisbury being available until the weekend.
mentioned right now:
Due to more trains than usual needing repairs at the same time at London Paddington fewer trains are able to run on all lines. Disruption is expected until the end of the day.
Impact:
Train services between London Paddington and Plymouth via Taunton and Exeter St Davids have been cancelled or revised. Pewsey will not be served.
Customer Advice:
Whilst Pewsey railway station will not be served by any train services, road transport will operate between Pewsey and Newbury.
With effect from Monday 10th May 2021 - CUSTOMERS INTENDING TO MAKE LONG DISTANCE JOURNEYS ON THIS ROUTE ARE STRONGLY ADVISED TO CONSIDER DEFRRING THEIR JOURNEY UNTIL A LATER DATE. CUSTOMERS WHO DO INTEND TO TRAVEL LONG DISTANCES ON THE ROUTE SHOULD BE AWARE THAT MOST JOURNEY TIMES WILL BE CONSIDERABLY EXTENDED, AS THOSE SERVICES THAT DO OPERATE ARE LIKELY TO BE EXCEPTIONALLY BUSY, CONNECTIONS CANNOT BE GUARANTEED AND IT MAY NOT BE POSSIBLE TO COMPLETE LATE NIGHT JOURNEYS AT ALL AS A RESULT.
We have had to adapt many of our High Speed service timetables into a series of separate shuttle services. This has been done to ensure that we are able to advertise and operate a limited but robust service using the resources that we have available to us. As a result, certain journeys which were previously through services will now require one or more changes of train to cover the same journey which may make them unattractive to those with large amounts of luggage or to anyone with mobility problems.
All of the through train services between London Paddington / Reading and Taunton / Exeter St Davids / Plymouth / Penzance, in both directions, have been withdrawn (a few of these services will operate between Plymouth and Penzance only utilising other carriages).
The local train services in Devon and Cornwall are not affected and will continue to operate as scheduled; it is only the through services to / from London Paddington which have been withdrawn.
CrossCountry train services between Bristol Parkway / Bristol Temple Meads and Taunton / Exeter St Davids / Plymouth / Penzance will continue to operate as normal and GWR ticket holders may use these services. However, there are no through train services between London Paddington and Bristol Temple Meads or Bristol Parkway so to connect into those services from London Paddington will require at least one other change of train.
South Western Railway (SWR) do offer a service to and from Exeter St Davids on which GWR tickets will be accepted. Whilst this would afford a connection at Exeter St Davids into / out of train services to destinations in Devon and Cornwall there are currently NO through services between London Waterloo and Exeter St Davids as an amended (Covid) timetable is in operation on that route so SWR services to / from Exeter St Davids only operate as far as Salisbury where connecting trains are available to London Waterloo, Westbury, Southampton, Portsmouth, etc. so that route may afford some journey options for those customers who would otherwise have used GWR services and changed at Westbury.
In addition to the revised train service arrangements GWR ticket holders may utilise the following First Kernow local bus routes, should they assist with individual journeys -
Route A17 Penzance - St Erth / St Ives
Route T1 Penzance - St Erth / Hayle / Camborne / Redruth / Truro
Route T2 Carbis Bay - Hayle / Camborne / Redruth / Truro
Route 27 Truro - St Austell
Route 87 Truro - Newquay
Route 91 Truro - Falmouth
Route U1 Truro - Penryn - Falmouth
Route U2 Redruth - Penryn - Falmouth
Fudgefrog
10 Feb 2009
Or HSTs - remember MK3s required extensive rewiring to make them suitable for push-pull LCHS use. If half your 43s had gone down with a common fault or safety issue, you’d have nothing to haul the carriages with?
Fudgefrog
10 Feb 2009
I find this analysis curious, given that TPE, Hull Trains, Avanti WC, East Coast Trains and EMR, as well as GWR with their 802s, all choosing the AT300 voluntarily and separately from the IEP. The Government-designed and run competitive programme might have been a mess and a shambles, but the actual end product has been pretty good for a new train.
DelW
15 Jan 2015
Indeed, especially as at the moment we have fleets from two unrelated builders (CAF and Hitachi) suffering from somewhat similar issues, of cracking at high-stress attachments to their bodyshells.
BR had a dual-sourcing policy after BREL was privatised, but that didn't necessarily work too well.
There were problems with one or other of the split fleets for Super Sprinters (155/156) and Networkers (465/466) and others.
HSTs were equipped with two types of engine and electrical equipment.
Every repeat 80x order also reduces the overall fleet costs and improved productivity at the maintenance depots.
O L Leigh
20 Jan 2006
In the cab with the paper
I'm not wading through 40+ pages to see if anyone else has raised this point, so I apologise if I'm just repeating something already said.
There are also issues with traincrew competency if you're going to go down the reserve traction route. It's not much good having a fleet of [insert preferred traction here] laid up in sidings if you've got no-one to work them. Route and traction retention costs money because you generally have to release traincrew from their usual duties, and quite a few TOCs have cut back on things like diversionary routes in order to reduce the number of route-refresh turns in the rosters.
AdamWW
6 Nov 2012
True, but two rakes each with one power car out of action still gives you one good rake.
With modern trains it just takes a software failure to knock the whole thing out of action.
We used to have a railway with multiple classes of locomotive and a large fleet of carriages which were compatible with each other. (Yes, not everything - steam heat vs ETH, vacuum vs air brakes). There were spare locomotives around that could replace a failed one if required. In the summer a freight locomotive could haul a passenger train. We had multiple units with the same couplings - a loco hauled train could couple up to a failed EMU and push it to the next station. A diesel locomotive could haul coaches that would normally be pulled by an electric engine without needing to have fancy couplings and computers on board.
Things are different now.
For a start trains are a lot more reliable.
It doesn't mean that what the railways are doing now is wrong, or that the advantages don't outweigh the disadvantages. But I don't really understand people trying to claim that actually there has been no loss of flexibility, when clearly there has, even if it is for very good reasons.
I think it depends what you think the railways are for. If you think they are an essential service and the most important thing is to always keep something running, then no.
If you think they should just be a nice thing to have and it's OK to tell people occasionally they have to drive or stay put, then yes.
The impression I get (and I may be wrong) is that over time the general view has shifted from the former to the latter.
Emaharg
28 Apr 2019
Someone said HST to me???
If the HST is ex Midland or ECML, it might not be fitted with ATP required for GW mainline into Paddington, coaches maybe useful for GWR power cars though. Such a shame there is no light engine moves from Kidderminster to pick up the rake, according to real time trains.
55002
16 Aug 2019
Ldn
5Z37 likely to be 37 688 hauling ex HST stock. Possibly staycation express? Two power cars went from Long Rock to Laira yesterday.
All these bar EMR were First Group procurements, probably with some sort of frame agreement with Hitachi which made repeat orders cheaper.
The first of these, for GWR south-west services, was heavily influenced by DfT who were extremely keen for 80x to be ordered.
The rest just followed on with the same basic spec.
EMR (Abellio) is a bit different, but again the DfT will have leaned on them to get them out of having cancelled the full MML wiring, requiring bi-modes.
So I think "voluntarily" is pushing it a bit, and no doubt they got a good price from Hitachi.
Bombardier and Alstom also didn't really have anything to compete in the UK, for what are quite small orders compared to the original IEP.
OldNick
24 Feb 2021
The South West
I did work experience at BAe in Filton, and got a small tour of an Airbus testing facility. They continue stress testing aircraft elements long after the planes have started production and are flying around. When they notice a crack developing after so many hours of "service" they design a part to bolt/rivet over the crack and send it out to their customers telling them where to fit it.
I guess you can overbuild parts and sections, but you want to avoid that everywhere for weight, cost and efficiency reasons. I don't imagine it's much different for rail.
