Energy-Initiatives in Rail
4 Jun 2008
Derby
Guys,
I know there is a lot being said about the environmental benefits of rail, but are there nay special inititives being run by any of teh major players? Would driver-style management be one such thing?
Metroland
20 Jul 2005
Midlands
Re-gen braking (AC and DC)
Cutting stock idling at depots
Station energy saving
Eco-mode on certain units
Changes to driving: More coasting for instance
DfTs electrification plan
I'm sure there are others but those are the ones I can think of
matt
30 Jun 2005
Rugby
I believe there were trials of Pendolinos coasting in Northern England or Southern Scotland
djw1981
10 Jul 2007
RSSB had a special pull out section about Environemntal aspects the other month in Modern railways IIRC.
IIRC te Pendo coasting was a temporary workround to get through a 1mile neutral section / OHL missing situation....
http://www.rssb.co.uk/publications/board_discussion/sustainable_development.pdf
http://www.rssb.co.uk/national_programmes/sustainable_rail/the_case_for_rail_2007.pdf
http://www.rssb.co.uk/publications/...ainable_development_appendices/appendix_5.pdf
TDK
19 Apr 2008
Crewe
Guys,
The company I work for certainly looks at the environmental issues and drivers are trained and advised on such matters, I feel that encouraging car drivers to take the train would have a much higher impact than a driver coasting a few miles though.[/I]
DaveNewcastle
21 Dec 2007
Newcastle (unless I'm out)
Well I quite agree about car drivers - especially when we consider the driving style of some of them (eg keeping the fuel pedal pressed when approaching a red light that aint going to change colour anytime soon).
But I think there's an excellent opportunity for further research into train power management too.
On diesel systems, the way that the power demands on the engines are not allocated efficiently across the power sources leads to massive waste. For example, the demands of all the non-motive-power facilities (eg Train Heating & lighting) may be better served by one engine running at high revs while stationary, rather than all of them running at a moderate speed below turbo speeds.
There seems to have been more work done on understanding power losses in electrified systems but I understand, sadly, that many findings are not actually implemented. One of the biggest savings would come from dynamic block switching of the power. This removes all the power leakage to ground when there is no train on the block. It also removes many electrical safety hazards which are often discussed on here.
