EMR Class 360's
hairybear
5 Feb 2013
Re 360, I am fully aware you have a unit on maintenence but for 21 units that's only 1, and GE managed to turn out 20 units.
IF you have "a couple out for repainting" that's still 18 - so something is badly badly wrong if there are another 6 stopped.
This is 60% availability only which is appalling for a type that generically can return 96%.
2 are on maintenance each day, 2 are at eastleigh for painting ,the remaining 5+ plus each day have faults bad enough to not be used.
They are 16 years old now and require a badly needed overhaul. Get used to it because this is how its gonna be for some time to come.:(
MML
25 Oct 2015
Are the EMR 360s now owned or leased?
I would be contacting ROG to see whether they would be willing to provide the 5 x ex Heathrow Connect 360/2 units on a short term lease.
They were stored at Bicester MOD awaiting express freight conversion, but ROG may be happy to sub lease them in the short term until conversion becomes imminent. A little extra income for ROG rather than sitting in sidings.
Wolfie
17 Aug 2010
I may be wrong but l thought that l read that there were significant differences in safety equipment. Also, who pays?
And the thing is - it really isn’t needed. Yes the trains are sometimes short formed, but in my experience of using them - in the peak - it’s not like they are crush loaded and people unable to board. North of Luton there always seem to be seats for those that want them.
43102EMR
28 Mar 2021
The ROG units were never planned specifically for freight usage - they bought them as spot-hire units for TOCs and FOCs…
MML
25 Oct 2015
If EMR are paying a leasing company for their units, they shouldn't be paying for the 30% which are unserviceable.
And the leasing company should be trying to remedy the shortfall, if necessary by looking at sub lease of alternative or supplementary stock.
Wolfie
17 Aug 2010
Depends on the maintenance basis in the contract surely.
F Great Eastern
2 Apr 2009
They dropped from Golden Spanner winners in 2019 at 84k MTIN to 18k I think within a year.
There's very much the belief that they were let go in terms of maintenance in their last year or so with GA. The 379s were not far behind them in 2019 but also saw a fair drop in 2020.
43096
23 Nov 2015
Could you explain what this means?
Dry - TOC responsible for all maintenance
Soggy - maintenance split; generally TOC responsible for day-to-day maintenance, ROSCO heavy work
Wet - ROSCO responsible for all maintenance
The short version is that in a wet lease, the Rolling Stock lease company retains responsibility for maintenance. In a dry lease they just provide the train, and the lessee does the maintainence. Soggy is somewhere in between.
(Clearly there’s a lot more detail than this).
Hairy Bear
13 Feb 2011
Derbyshire
Siemens maintains them. But there's not enough staff and there not in the right place when required.
The service is run on a wing and a prayer each day !
The term comes from aviation, where a dry lease is just of an aircraft that you then operate yourself, whereas a wet lease is of an aircraft and crew etc to operate on your behalf.
That probably comes from something else, though!
colchesterken
Seems to me the people at EMT do not know how to love and care for them
when we had them on GE they were year after year the best performing units in the fleet
running flat out on the Ipswich and Clactons all day
Bikeman78
26 Apr 2018
Are you able to elaborate on the nature of the faults? Any cab faults can be buried in the middle of pairs, assuming the faulty cabs aren't all facing the same way. The battered Greater Anglia class 317s routinely achieve better availability.
cjmillsnun
13 Feb 2011
With respect the hammering they had on GA may well be responsible for their issues now. They should’ve been comprehensively refurbed inside and below the solebar prior to going in service.
Also don’t blame EMT. They haven’t existed for 2 years now.
Bikeman78
26 Apr 2018
Something has gone wrong then. The idea of the Corby trains was to soak up passengers from the longer distance trains. If the long distance trains are wedged (as reported on other threads) but the Corby trains don't even fill four cars, then the plan doesn't seem to be working.
samuelmorris
18 Jul 2013
Brentwood, Essex
Clearly they were neglected in their last days at GA, just as they were years prior before negative PR started to get under the TOC's skin and they started making some effort to make stock presentable again. That in my opinion though, is largely irrelevant. Even if the interiors are shabby due to a lack of staff after Covid, the rest of the units should really have had an overhaul before introduction to service, they had plenty long enough. I'm not especially impressed with what I've heard so far.
43102EMR
28 Mar 2021
Indeed they were - having travelled on them on many occasions just before they left, it was evident they were in desperate need of TLC and that GA were running them into the ground…
Hairy Bear
13 Feb 2011
Derbyshire
Not personally as I don't prep them for service.
But usually the faults are on the traction package, door and toilet faults that are serious enough for them not to be used.
There's no Siemens staff there when the sets are prepped, therefore there not used, also not practical to start shunting sets around as there's no space or time allowed to do it.
The management have put no thought into potential failures each morning and the potential to elliviate them for short formed services.
colchesterken
Could they go to Ilford for repair under some sort of contract. they serviced them for 12 yrs and must know all the tricks to fix the problems.. Or even lend Ilford fitters to EMR to train their staff on the short cuts, they were top of the reliability sets for years they must basically work
I’d be very surprised if the long distance trains arriving at St Pancras in the morning peak are wedged. Indeed I know they’re not as I’ve seen them!
Wolfie
17 Aug 2010
In the main l agree but the rot set in with GA's lack of maintenance in their final time there. As others have already said reliability plummeted. Presumably hefty remedial work is now required.
43096
23 Nov 2015
Heavier maintenance is already contracted to Siemens at Northampton. Given a 360 is essentially a 350 without end gangways I don’t see what sending them to Ilford is going to achieve, especially as reliability dropped significantly when Ilford maintained them once Siemens were no longer involved.
Bikeman78
26 Apr 2018
There's plenty of reports of Sheffield and Nottingham trains being full at "off peak" times. What are the 360s like at those times? Are they full too?
Starmill
18 May 2012
Bolton
Is it so inconceivable that there are times of day when a lot more people might want to go between Leicester / Loughborough / Nottingham / Derby / Chesterfield / Sheffield and London but not that many between Luton / Bedford / Wellingborough and London?
A large part of why electrification and more trains was paid for in the first place was the significant number of office commuters who used Luton or Bedford to get to Central London most weekdays. Not exactly the current state of affairs.
