EMR Class 360's
dmncf
4 Sep 2012
Thanks. Does anyone know if this path today 0918 Ilford E.M.U.D. to Willesden Up & Down Relief is related to the 360s or something unrelated?
D_MTrains
12 Jul 2020
Kettering
How many 360s have been currently upgraded at Northampton and how many does that mean there is to go?
As well as that, is there any idea as to when driver training is set to start; considering the units go off-lease August 31st and the wires are energized (Bedford - Corby) on August 23rd (what I heard), could this potentially seeing the new units on training later this year?
43096
23 Nov 2015
Three completed, with a fourth on its way from Ilford currently. That leaves 17 still to go.
43074
10 Oct 2012
Ah, that makes sense. Good to see they will have some form of a proper depot on the Midland. Thanks Both.
For the heavy maintenance it is assumed a unit will always be elsewhere as there won't be many diagrams which actually cycle through Cauldwell, a trio overnight and between the peaks IIRC.
Pippy1505
4 Nov 2010
1st units for training in December
T-Karmel
20 Mar 2010
I thought maybe it'll help someone here. I've just passed First Class carriage of GA's Class 360 hauled on the road on M40 Northbound in Waterperry like just 5 mins ago.
43066
24 Nov 2019
And aren't the HSTs meant to leave service at the end of 2020, being indirectly and partially replaced BY the electric 360 services?
HST withdrawal now been pushed back to May, at the earliest.
OTRail
14 Jul 2019
I saw that too - why did that movement occur?
Class 170101
1 Mar 2014
First class only behind cabs of GA Class 360s so if it was anything other than a cab it wouldn't have had First Class
43096
23 Nov 2015
360118 back to Ilford yesterday as 5Q60 1131 from Northampton; next one currently on its way over as 5Q60 1650 from Ilford.
londonmidland
22 Dec 2009
Leicester
EMR doesn't use the Slows south of Bedford except during disruption or engineering access, and I can't see that changing. Anything on the Slows would soon catch up a Thameslink stopper.
I think the OP was indirectly pointing out that electric trains are currently limited to 100mph(?) south of Bedford on the original BR electrification.
capital12
20 Aug 2012
If they were simple to paint on top of, somebody would have repainted one by now.
I’m not sure I know of any reputable paint shop that would simply ‘paint on top of’ the existing top coat and a repaint would usually involve sanding back the existing paint before applying new.
Or are you saying that this paint is repellent to sand paper too?!
fgwrich
15 Apr 2009
Hampshire
The answer to this question is... Brodie’s in Kilmarnock. Presumably they have the refurbishment contract and have taken a fairly intact looking 360116 as a trial.
delt1c
4 Apr 2008
Not sure what you mean. Behind the cab could be either standard or 1st. Plus 1st can be positioned anywhere in the unit
Class 170101
1 Mar 2014
The GE Class 360s have a small first class seating area behind both cabs so the vehicle seem had to be a driving cab. No intermediate vehicles have 1st Class in them.
MML
25 Oct 2015
Do we know how the unit's are to be configured by EMR ?
I presume one of the 4 carriages will be dedicated to first class rather than the current 8 seats squashed behind each cab.
That would provide 2 first class carriages per 8-car unit and 3 per 12-car unit which seems about the right ratio for a longer distance commute.
Just a gentle reminder this thread is to discuss EMR Class 360s
If anyone wishes to discuss anything else, please create a new thread (if there isn't already an existing thread)
Thanks.
Railperf
30 Oct 2017
Thanks for that.
From posts upthread, the increase from 100 to 110 is achieved, in the case of 360s, by changes to the motors rather than re-gearing. Re-gearing to increase maximum speed reduces acceleration rates because the power is unchanged but I'm not sure whether the motor alteration adds to the top speed by extra power and so does not affect the acceleration. I'm just interested; if the acceleration is reduced (and I accept that it might not be), whether the extra 10 mph over one section (which includes the Wellingborough stop) saves more time than the penalty of slower acceleration away from calling points (I make that 5 starts, 6 if St Albans is served).
I accept that, once St P -Bedford becomes 110, the advantage will lie with the higher speed.
Class 350s modified for 110mph have the same acceleration rate as the original 100mph versions.
They were not regeared.
The 360 mods will be the same.
43096
23 Nov 2015
The moves from/to Northampton for this weekend show as cancelled, so presumably 360106 remains there.
Alfie1014
27 Jun 2012
Essex
The irony in that statement is that the routes they are currently on (Clacton 90 minutes and Ipswich stopping 80minutes) are longer than the ones they are going to be on!
LowLevel
26 Oct 2013
Albeit providing different functions - the likes of Kettering and Wellingborough have 'intercity' fares which are much more expensive than neighbouring Northampton on the WCML so the standard of rolling stock has to be considered as I doubt they will be planning fare cuts.
Merle Haggard
20 Oct 2019
Northampton
Clacton mp 69m 56ch, Ipswich 68m70ch versus Kettering mp 72m 01ch and Corby mp 79m40ch.
mp - mile post (distance from London termini)
Edited to correct typo
Indeed, thanks - Edited. I'm using m.p.s from the very useful Track Atlas. I think MML m.p.s are from the 'stops under the clock at St. Pancras, so slightly too great for present layout
Yes, I believe the current platform starter signals are nearly at the old quarter milepost.
MML
25 Oct 2015
It's certainly going to be interesting how the layout of each standard 4 car unit, multiplies and duplicates resources compared to a fixed formation of 5 or 7 coaches.
I imagine each unit will be equipped with a disabled toilet and seating, 2 cycle spaces which takes up space, and then you need luggage racks similar to the 700s for airport passengers.
I can’t really see a whole First coach on a four car EMU, as suggested a few posts back. Is there any sort of precedent for that at all, looking across the whole fleet of four car Desiros or Electrostars, or similar equivalents?
