EMR Class 222’s - declining reliability
Amos390
22 Jan 2025
One wonders what analysis is done of engine failures. It could be a genuine mechanical fault, such as a blown head gasket, it could be transient, such as coolant overheated triggering a shutdown, or it could be plain lack of attention, such as running out of fuel.
From what I’ve seen on shows and observed on timetables, the unit is first given an off-on (or a tech will have a look at it if possible) at the next station call, and if the unit can continue on to the end of the day it will, if not it will be pulled, then as part of the overnight maintenance of the fleet they’re assessed and fixed up before the following day of service (if possible), or we have a 222007 scenario where the unit sits around the depot for months waiting for parts…
Trainman40083
29 Jan 2024
Derby
Maybe they can take some parts, off the one sitting on Etches Park with cab damaged . 021? That said, there does seem to be a spare van, visible in the yard.
Taunton
1 Aug 2013
And then one has to question why you are "waiting for parts". It can be, of course, they have to be custom manufactured. But it can equally be the stores have run things too thin and they have just run out. Or even the budget for a particular area has been spent and nobody will do a budget variation until the new financial year comes around, the problems this gives to the operating team being "not my department".
Trainman40083
29 Jan 2024
Derby
Maybe they wound their spares down, thinking they wouldn't be needed, as all the 810s would be in service.
Amos390
22 Jan 2025
The parts may not be something that is readily available, I gave 222007 as an example, that needed an entirely new front cab housing, EMR don't just have one of them lying around the place, things like that need to be fabricated from the manufacturer and shipped over. Then comes all the testing to make sure the new part(s) are working as they should, which all in all can lead the unit to be out for quite a long time.
Trainman40083
29 Jan 2024
Derby
Well, there is certainly a spare cab housing at Etches Park, but maybe demand has increased recently... Now when you go past the Bombardier depot at Central Rivers, you can also see a number of spare cabs. I'd have thought with few spare units, it is a certain strategic spare.
Taunton
1 Aug 2013
Really? Eurostar used to have their spare cab housing replacements sat outside the depot at Stratford, you could see them there as you drove up Orient Way. It's a matter of organising your spares. They are something that does get damaged from time to time. Here they are, three of them :
LowLevel
26 Oct 2013
It's a fairly regular part to replace to be fair, most rail vehicles fabricated in such a way have a decent stock of spare cab shells. HSTs were the same.
Amos390
22 Jan 2025
Ah I wasn’t aware of this, must have been ill-informed at somepoint along the line.
Did however hear from a driver today at Notts that the reason why 222104 (and eventually other 222s) have been pulled from service so early for ScotRail is that the 222s have been sold and technically are no longer are owned by EMR, however due to the delayed release of the 810s they have been told they can keep the 222s for a bit longer, however as soon as a 222 gets brought in for heavy maintenance (which is what happened with 104), it gets nabbed by the leasers. The driver also said that the usual number of engines that a 222 runs on is 3, which is one more than the boundary of 2 that needs to be met before the unit is pulled from service (however the unit he was driving, 222017, had all 5 running miraculously)
23 Nov 2015
The 222s have not been sold and technically have never been owned by EMR.
liamf656
2 Aug 2020
Derby
Not quite right. The 222s are not owned by any TOC, but leased as mentioned above. And the comment about a unit going in for maintenance to be pinched by the leasing company is false too. There is a specific order the units are returning in. Starting with the ex 4/7 car units, which is why 104 has gone (and 103 will be next)
Amos390
22 Jan 2025
This is what I was told by a driver at the station yesterday, just relaying what I was told
duffield
31 Jul 2013
East Midlands
1D66 1805 St Pancras International to Nottingham cancelled today when I was sitting on it waiting to depart, we were all chucked off at about 1815 due to an unspecified train fault. I think the failed 222 had already substituted for a failed 810.
Not fancying the 1835 stuffed with two trainloads of passengers on another 5 coach 222, I legged it over to Kings Cross, got the 1833 Newcastle service, changed at Grantham (with about 60s to spare!) and got back to Nottingham 2 minutes before the 1835 arrived ("engage smug mode" as Kryten used to say).
720144
26 May 2024
uk
According to rtt, the unit that failed was 222015.
notadriver
1 Oct 2010
I'm sorry but I strongly disagree. The 222s are a great train but are heavily used, Lumo should use electric trains on a wholly electrified route, with Avanti using only electric trains into Euston seems a backwards step having diesels back there. Also it's not fair for passengers weekends can be horrendously on EMR IC especially when the football or other big events are on, much worse now then with their availability without any having left.
What has happened to the 350s ? Would they have been better for Lumo ?
If there are so many engine issues with 222s would it be worth introducing a temporary timetable with a 100 mph speed limit to mitigate engine failures ?
Trainman40083
29 Jan 2024
Derby
I did wonder about the 350/2s. Think they have 3 + 2 seating. Wasn't the lease charge high on those (due to interest rates at the time they were built)?
Clarence Yard
18 Dec 2014
Lumo had no interest whatsoever in the cl.350 units - they are outer suburban EMU’s.
The cl.222 units were what they were after and that is what they got. Nobody else was going to decide what stock they could lease.
Qwerty133
7 Oct 2012
Leicester/Sheffield
With a reduced timetable now in place for the next week requiring significantly fewer units I am hopeful that a number of those niggling faults that aren’t severe enough for a unit to be taken out of traffic will be able to be fixed during this period.
liamf656
2 Aug 2020
Derby
Fingers crossed, although it'll also be interesting to see how the network copes with the extreme heat that is forecast this week
Amos390
22 Jan 2025
Maybe the MML will manage somewhat better than other routes due to the reduced timetable, more wiggle room for if something goes wrong
DannyMich2018
19 Dec 2018
Or even just run a sole 222 operated service and try and bin the very unreliable 810s for a week- pretty much every day an 810 fails in service, give them some time to sort them out.
800001
24 Oct 2015
There is only so many mechanics on duty each day which will
Already have work planned for certain units.
You are not miraculously going to sort out what ever is causing the 810 issues in a few days.
liamf656
2 Aug 2020
Derby
222007/015 are being brought back to Etches Park for maintenance, having been trapped in London since Friday's incident. They are utilising the ECML for this
Russel
30 Jun 2022
Lichfield
222007/015 are being brought back to Etches Park for maintenance, havjng been trapped in London since Friday's incident. They are utilising the ECML for this
Would that be under their own power and who would be driving as I can't imagine EMT drivers sign the ECML?
Amos390
22 Jan 2025
Will be under their own power looking at the timing codes (125moh DMU), not sure about the drivers, maybe EMR supervised by FL who have the route knowledge or something (not sure if that can happen, just a guess).
liamf656
2 Aug 2020
Derby
Believe it's an EMR driver providing traction knowledge, and another driver from elsewhere providing route knowledge
Europhoenix are doing the movement
Amos390
22 Jan 2025
