Just been planning a trip from Wellingborough to Luton tomorrow and have noted that a special timetable is in place. Except when you look at the PDF timetable issued by EMR for tomorrow it's impossible to travel between the two stations as all southbound departures from Welly run direct to St P, and there's a separate Bedford - St P stopping service starting from Bedford. It's only when you try one of the booking engines you find that the Bedfords actually start and terminate at Wellingborough and you CAN travel direct between the two. So my question is what earthly reason could there be for not showing the stoppers as starting from Wellingborough in the published PDF timetable. Simply weird.
