Emergency stop buttons
eastrail
25 Mar 2025
Are there any emergency stop buttons at platforms such can be operated by passengers on the Tube? I have seen this in other cities but not sure about London
Russel
30 Jun 2022
Lichfield
I believe the Central Line does and possibly the Victoria.
Russel
30 Jun 2022
Lichfield
On these Lines, the only ones fitted, a train operated in Restricted Manual will not be stopped by a platform stop plunger.
Ah okay, I've no idea how they work, I've just noticed he buttons on the platforms!
TFN
17 Aug 2017
Not LU, but Elizabeth Line at Custom House and Abbey Wood have Emergency Stop Plungers.
eastrail
25 Mar 2025
I ask because I have seen a post or two on social media about people panicking about what to do when they see a person on the track. My immediate reaction was to activate the emergency stop or plunger, until I realised I don’t think I had ever seen one on the Tube. Glad to know they do exist on some lines, though I imagine it would beneficial to have it on all lines? I think trains in RM not being stopped is fine since the train should be travelling slow enough for a swift stop.
Interestingly, many Asian metros are equipped with emergency stop buttons on platforms, despite the platforms having platform screen doors.
bcarmicle
11 May 2018
In practical terms, if you do see someone on the track, hit the emergency button on a Help Point, or if someone has already done so, stand between where a train would enter and the person (though on the platform of course), with two hands straight up in the air.
Daniel
5 Oct 2005
Two arms waving above your head. Straight up in the LU Rules is "stop at me" whereas waving is "stop immediately". I understand this is different in the Network Rail rules which is where the confusion may be from.
Central
20 Oct 2017
Irthlinborough
Used to get a lot of malicious operations.If I remember correctly an alarm sounded as well if one operated.They only had paper seals.
MaidaVale
18 Jun 2021
Reading / SW London
The plungers on the Central and Victoria lines aren't actually Emergency Stop plungers so to speak, but known as "Codebreakers". All they do is kill the ATP/ATO code which provides the train with instructions when in Protected (Coded) Manual or ATO driving modes. This won't necessarily guarantee the train will stop, so they shouldn't be used as the only method to stop a train in an emergency, at least not by staff.
As mentioned by someone else, it won't have any affect on a train in Restricted Manual driving mode. All it does is drop the target speed indication to zero which will bring a train in ATO/CM to a regular stop. Getting a zero code is also not unheard of in regular operations if there's an ATP failure or simply if there's another train ahead, so it wouldn't necessarily indicate an emergency ahead to the train operator, and in theory wouldn't stop a T/Op continuing in RM (although obviously this would be a major rule-break without speaking to the Signaller/Controller first).
It won't switch traction current off, it won't necessarily immediately emergency stop all trains in the area, and depending on the location it might not affect both travel directions (for example on an adjacent track) so should only really be used in conjunction with a hand signal to the driver or one of the other ways of bringing a train to an emergency stop in accordance with the rule book. Best to think of it as an extra step, and not the only step to stopping a train in an emergency. It's certainly better than nothing though.
Northerngirl
16 Aug 2023
Wirral
Are the dlr ones a similar system, or does that cut the power. Its such a shame that there is misuse, as it would be a fantastic safety tool
SECR 65
2 Apr 2026
East Sussex
Stopping an LU train arriving into a platform must be tricky. Given that braking is already quite 'harsh', how much additional brake force do the trains have? E.g. if a train operator recieved a stop signal when just arriving into a platform, would they be able to stop any sooner than the normal stop marker?
Mawkie
17 Feb 2016
Can only speak for '73 stock, but at the speeds I come into platforms, the answer is "not much" - perhaps a car length prior to the actual stopping mark, at the most. Obviously slower drivers have more opportunity for stop shorter.
Central
20 Oct 2017
Irthlinborough
On the Victoria Line if someone pushed an emergency button it killed the code giving an emergency brake application.
Egg Centric
6 Oct 2018
Land of the Prince Bishops
Do 73 stock have a Westinghouse brake like the 72 stock? if so do you have enough time to react to an EPB failure without an overshoot? Doesn't sound like it - I assume this is fine cause there's plenty of signal overlap and it's a backup brake rather than something to allow normal driving?
styles
7 Dec 2014
Gwynedd
How much misuse do these buttons get?
Not sure on the misuse in practice, but they basically haven't resulted in prosecution:
Date: Friday 6 January 2023
Since 2016, TfL has not pursued a prosecution or issued any penalties related to improper use of the emergency alarm.
I think it's a bit like people calling 999 because the Chinese takeaway messed up their order - the authorities don't generally want to penalise people for misuse because in the event of a real emergency they want people to feel empowered to use them still without fear of getting a criminal record. I think you would have to be very obviously trying to cause disruption for a prosecution to be pursued.
