Elizabeth Line - future extensions?
Cost about the same? You'd only require a roughly 2km tunnel from Poyle to T5, whereas with the Western Approach a 5.5km tunnel is planned.
Less useful? Perhaps, but we have had several major transport investments in the area recently and we shouldn't keep going for the "gold standard" option (unless Heathrow is paying, of course).
The tunnel is only part of the cost…
AlastairFraser
12 Aug 2018
Transit Orientated Development - essentially a Yank term for houses built primarily around a public transport node (e.g. a station), where the inhabitants are intended to travel using the transport services at the node for basically every journey they make.
The tunnel is only part of the cost, but the modifications needed to the GWML between Langley and Iver wouldn't be cheap either.
AlastairFraser
12 Aug 2018
Well yes - and certainly at the western end, it is probably over-capacity west of Shepherds Bush/White City. Creative minds, of which we have many, could maybe do more things with it. Uxbridge was mentioned for a while, but I would suggest that is also served plenty.
It certainly wouldn't be a priority, but a tunnel Ealing Broadway to West Ealing and a take over of the Greenford branch line would certainly help boost passengers numbers on that line and utilise spare capacity on the Ealing Broadway Central Line terminators.
Nor at West Drayton…
Depends, if you kept it as a eastbound only loop (as your basic option), it wouldn't be horrendously expensive.
Mikey C
11 Feb 2013
On the Southeastern side, restoring frequencies on the Southeastern routes would be a far cheaper way of increasing capacity than extending the Elizabeth Line.
In a world of limited budgets, passenger journey time is not the metric to judge everything by.
The point being:
spend nothing, no increase in journey time.
spend the best part of a billion - increase journey time.
which option makes sense?
AlastairFraser
12 Aug 2018
The point being:
No increase in journey time for T5 - western GWML, but a more seamless changeover than at H and H.
Either way, it's a marginal project that would only go ahead with Heathrow money.
It’s not marginal, it’s an absolute no-hoper, and Heathrow wouldn’t touch it.
Heathrow weren’t interested in payinng for the Western or Southern links either, unless they were forced to as part of the third runway plans.
AlbertBeale
16 Jun 2019
Or as part of being forced to ensure that an increasing proportion of the access to the airport is by pubic transport.
AlbertBeale
16 Jun 2019
That would need legislation. Although I hope you mean Public.
Woops - thanks - my mind might have been wandering there...
But I'm not sure about legislation - presumably planning permission (such as for expansion of Heathrow or something else the airport wants, even short of a third runway) could have conditions attached, such as any growth in passenger numbers needing to happen without any increase in road movements to the airport. If the airport wanted to expand, it might then need to fund more rail infrastructure.
leytongabriel
27 Jan 2013
Yes very well filled in the centre but there's a lot of air being carried to Shenfield. Romford ( or Gidea Pk for turnround) to Shenfield really doesn't need current level of off-peak services, seems quite wasteful. So an alternative eastern terminus would be good. Id connect up the Lea Valley personally, know that would mega work would be needed in the Stratford area, but there's a big poverty zone there, desperate for an econmic boost.
Sorry yes, that’s right, but that’s what I meant (but didn’t write) as ‘part of the third runway plans’ which included new terminal(s).
But it’s reasonable to assume that the suggested ‘loop’ back to West Drayton would do little if anything to improve public transport usage. It would probably make things worse, to be honest.
How could linking up the Lea Valley even be done without defying the laws of physics given all the buildings and other railway lines at Stratford?
AlastairFraser
12 Aug 2018
If you wanted to divert some EL from east of Stratford, sending some services off the GEML reliefs at Forest Gate junction onto the Gospel Oak to Barking line and then taking over the portion of the c2c Fenchurch St to Southend Central via Grays service east of Barking would be a decent idea.
This would provide direct service between East London and South Essex, including Lakeside Shopping Centre (connected to Chafford Hundred station) and Stanford-le-Hope/Tilbury for the ports near those stations.
Problem is that the capacity the Elizabeth Line offers in East London is needed out to Romford and Gidea Park. It is essentially east of there that the trains carry fresh air. Turning off at Forest Gate would be too soon.
TrainBoy98
19 Mar 2012
Worthing
Aware it would take a fair bit of work, and a fair bit of cash, but hypothetically a couple could head from Romford down to Upminster, replacing the Overground.
Not too sure Upminster needs more connections mind, but could free up some space on LTS
The passenger loadings at Emerson Park would never justify that cash.
AlbertBeale
16 Jun 2019
And of course (in the same hypothetical spirit) they could then continue on, taking over the branch from Upminster down to Lakeside and Grays too.... with another "fair bit" of work and "fair bit" of cash. Crayons are such fun if you don't look closely...
TrainBoy98
19 Mar 2012
Worthing
Very true.
Yes, hypothetically of course (tis "speculative" section after all - some crayon moments allowed :lol:)
Basil Jet
23 Apr 2022
It's only so poorly used because it's so poorly served. There's no intrinsic difference between the houses around it and those around nearby District Line stations.
Acton1991
20 Jan 2019
They definitely need to find a way to add more services on the Western branch. Very heavily loaded in the peaks with some stations only receiving 4tph.
PeterC
29 Sep 2014
Fair bit? I think a shedload of cash and a shedload of work. The EL uses the Electric Lines on the North side of the GEML while the branch is to the south of the Main Lines. Having 2tph blocking both mains and down Upminsters blocking the Up Electric as well is unlikely to be feasible
At the moment getting a train on to the branch requires 2 reversals on the mains.
