Electrification threads and resources index
Mordac
5 Mar 2016
There used to be one very nice interactive map with ongoing and planned electrification works, would anyone have the url handy?
5 Aug 2015
Norfolk
Northampton
Hefty pinches of salt required when it comes to "propesed electrification" on ORM. It still shows HS2 going through Leeds as well as in-fill schemes for Wokingham/Aldershot/Guildford/Reigate.
Oh I know.
However, they've just started showing susbtation locations (if you zoom all the way in) which is welcome upgrade
Yes, the new app version is quite nice.
Morayshire
6 Feb 2019
Interestingly "James Wemyss" over on the Scot Rail Io group has been through the Network Rail Engineering Access Statements and has highlighted the following:
I decided to check if there were any new or updated versions of the Engineering Access Statement (EAS) showing on Network Rail's website.
A version one of the period between October 2027 to March 2028 has been released but not a version of the period between March 2027 and October 2027 yet.
Use this link, then click EAS, click the year you want in this case 27-28 and then the version you want that at the moment is only V1. Scroll down and you want SCO (Scotland) and the S7.pdf file. View on the web or download / save copy to your device.
I haven't had time to study the new/latest releases fully but the 27 to 28 document lists: Dundee Station Project resulting in its full closure during the set possession periods, ARU Project at Perth (what does the ARU stand for as some of the possessions when this appears are from Dunblane to Dundee whilst others are Perth to Stanley SB?), Muirton Project including Muirton S&C (notation says 'pre work EIS' so I'd presume a significant package of work that requires clearance of an Environmental Impact Statement with the Council?), the new through platform at Arbroath built during a four week closure of the line between Errol/Leuchars and Craiginches (Aberdeen) with various bridge projects included during this period (29th Feb to 26th March 2028 inclusive).
A2CB expecting to recommence but now called the ARU Project?
The 27 to 28 EAS also has further WHL and Kyle block periods.
If he is correct then we have some chunky works coming up in the Dundee area and some rather interesting works at Arbroath (new through platform, hmmm).
I'll fix the link in the quote once I get near a PC
Link to Network Rail Engineering Access Statement (EAS) page
EIS is “Entry Into Service”
GRALISTAIR
11 Apr 2012
Preston Lancs
2026 Electrification Threads Current
This is a summary of all threads currently open, specifically about electrification
Transpennine Route Upgrade and electrification
Haymarket to Dalmeny electrification
Fife Rail Electrification/Decarbonisation
South Wales Metro updates
Borders Line (Scotland) electrification news and updates
Dundee electrification plans
Acton Main Line to Acton Wells Jct Electrification
GRALISTAIR
11 Apr 2012
Preston Lancs
July 2026- December 2026 Electrification threads
Transformer arrangements in Autotransformer 2 x 25 KV systems
Electrification changes- new masts etc - near Slough
Anyone know what this tender is about, or where it is for ?
Colas Rail UK intends to procure and operate a Wiring Consist for the installation of contact and catenary wire.
The Consist comprises of two powered modules
Wiring Module a self propelled rail vehicle equipped with a four cable wiring module and two capstans.
Stringing platform a self propelled vehicle equipped with an elevating/rotating platform and one wire positioning unit.
Colas Rail requires specialist technical support from a suitably competent organisation to
Assess and recommend the most appropriate operational and certification strategy for the Wiring Consist.
Identify the applicable UK legislative, standards, compliance and acceptance requirements.
Support the development of a technical specification suitable for procurement and tendering to manufacturers.
Support the definition of the certification and acceptance process for the selected solution.
Provide technical support during manufacturer engagement and subsequent certification activities, as required.
Nicholas Lewis
9 Aug 2019
Posted here as its system wide.
NR has let a £240m Network Rail OLE steel supply deal
https://www.constructionenquirer.co...amed-for-240m-network-rail-steel-supply-deal/
The winning firms are:
Steel Piles (£70m):
Adey Steel
European Active Projects
Severfield Structural Solutions
Steel Structures (£99m):
Adey Steel
Fullmen
Pro Steel Engineering
Taziker Industrial
Other winners for the smaller lots include:
Associated Utility Supplies
Folglade (Pipes and Fittings)
Railability
Trackwork
Balfour Beatty Rail
Furrer + Frey GB
Gripple
The contracts are set to start in January 2027 and last for a minimum of six years with a possible two-year extension.
So a six year contract covers well beyond whats in progress now so gives them options should DfT come to it senses later in the decade.
The exile
31 Mar 2010
Somerset
InTheEastMids
31 Jan 2016
Could this be a sign that they have been tipped the wink about a policy announcement?
We've had so many policy and pipeline announcements that just get quietly erased (e.g. Electric Spine)
Then we've had situations like MMLE, which has been on and off more than my accursed work laptop. The most recent cancellation happened so late that compounds were being stood up, piling locations marked and NR comms had to invent spurious reasons for a 6 month road closure to rebuild a bridge near Loughborough because it was past the point of no return. There are still bits of galvanised OHLE steel lying around in abandoned compounds along the MML.
So they can "policy announcement" all they want, but I wouldn't believe it's actually real until it's all built and ready for energisation. The supply chain knows that Government has acted in a deeply unserious way when it comes to electrification and will presumably have priced accordingly.
TrainViation
25 Jun 2025
Glenrothes
I'm pretty sure this 2027 announcement is to do with the Dundee electrification plans, given the 6 year timeframe. And as with Scotland and it's electrification, it seems highly likely that this announcement will materialise and contribute to the large scale project in the north of the country.
