Oxenholme-Windermere.
That one is actually One Train Working (with train staff) as opposed to Electric Token Block.
There are a few lines (Central Wales, Whitby, etc) using No-Signalman Key Token.
Dunragit - Glenwhilly - Barrhill - Girvan still uses the older tablet instruments.
I believe Aylesbury to Calvert is also signalled in this manner? May have changed slightly since the Parkway was opened, not sure.
What about Llandudno Junction - Llanrwst - Blaenau Ffestiniog.
Token instrument in the 'station office at Llandudno Junction as well.
Dewsbury Cement,
Clayton West Junction to Penistone, Electronic token Less Block
Leeds Subs 783/784 Neville Hill Sidings to Hunslet East.
Hunslet UP to Stourton Stone Bunker.( 6E17/6M17 Peak Forrest Stone)
There are quite a few lines using Electric Token Block or a variant of it that has a key token taken from an instrument. Immediately springing to mind are:
Some sections of the Cumbrian coast such as St Bees-Sellafield.
Midge Hall-Rufford.
It's worked by Track Circuit Block now; no tokens are involved.What happens between Evesham and Worcester these days?
Is Blackpool South to Kirkham & Wesham operated by Electronic Token?
Rainford - Kirkby!![]()
[Rainford - Kirkby] I'd have thought that just a One Train Working staff would be sufficient as it is a simple dead-end stretch of single track.
Maiden Newton to Yeovil Pen Mill is No-Signalman Electric Key Token. It was introduced in 1988 when the signalbox closed.
This is a very interesting example, an island of No Signalman Electric Key token. Castle Cary to Yeovil is Track Circuit Block, as is Maiden Newton to Dorchester West. Anybody any knowledge of the history of this, and why the Track Circuit Block wasn't extended to cover the whole line? Is it a case of a manual section between to power signalled areas because the panels won't 'talk to each other'?
