Electric/Diesel Locomotives?
GNERman
8 Oct 2008
North Yorkshire
the class 73 runs on both Diesel and 3rd Rail as do some others
Why don't we have locomotives that run on Diesel power but also have a pantograph so can run on Overhead Wires
This would be great for Multiple Units and DEMU's as the power could go straight to the motors.
mbonwick
26 Oct 2006
Kendal
Perhaps because a diesel engine needs a generator attached to it, and OHLE requires a transformer to be fitted to the loco. Both very bulky bits of kit ;)
P156KWJ
26 Nov 2007
Nottinghamshire
I think there's one in France that can run off all 3, but I might be mistaken. You could have a double loco welded together (like a class 13 but bigger obviously)
mbonwick
26 Oct 2006
Kendal
Would be a bit pointless though, increasing length and weight without increasing power...longer trains, slower acceleraton etc
jopsuk
13 May 2008
It's one of the many things wanted for the frankenstien IEP trains (or at least some of them). Obviously it is technically feasible- the traction motors should in theory be able to operate without "knowing" whether the electricity is coming from the prime-mover or via a pantograph and transformer. As said, it's mainly a matter of weight.
delt1c
4 Apr 2008
The prototype 210 was designed to work in multiple with 2nd generation EMUS , also the 1st refurbished 205 was also fitted with controls for multiple working with EMU's, OK not quite a hybrid and wouldnt be able to drag the emu away from the volts but it was a start.
mbonwick
26 Oct 2006
Kendal
I think the key thing with them is the 1500v, which doesn't need a transformer. 25Kv does however.
