Electostars vs desiros
Class313:)
25 Jan 2018
Barnet
wondering what opinions on this are, having not been on electrostars that much, and only occasionally on Desiros
SEClass375
16 Aug 2016
Having been on both a Class 375 (what I travel on most of the time) and a Class 450, I personally prefer an Electrostar. Whilst a Desiro has a slightly better build quality over a Mk1 Electrostar, an Electrostar has a better interior, comfort and ambience and a better PIS system.
Desiro has a marginally better build quality, however from an ambience point of view I prefer the Electrostar, especially the earlier versions.
A certain amount is down to specification however - the Connex interior Electrostars I find excellent, although they can be prone to rattles.
Later Electrostars have a better build quality, however sadly the seating is horrible.
Class313:)
25 Jan 2018
Barnet
How many connex electrostars are there....they have no franchises. 376s and 375s ive seen in connex livery, but havent SE refurbrished the interior?
SEClass375
16 Aug 2016
Connex spec built Electrostars are Class 375, 377101-139 and Class 377/3
Connex spec built with 2+2 seating are Class 375/3 and /6-8, 377101-119 and Class 377/3
Mk1 Electrostars are Class 357, Class 375, Class 376, Class 377/1-5
Mk2 Electrostars are Class 377/6 and /7, Class 379 and Class 387
davetheguard
10 Apr 2013
I definitely find the seats more comfortable in the Desiros, and seemingly the later the build of Electrostar, the bigger the gap in favour of the Siemen's-built train.
Buggleskelly
28 Jun 2017
Bishops Wallop
I've only ever travelled on one class per family, 360 and 357. I tend to travel on the 360/1's more as they take me to work more or less every day. Seating is quite comfortable, nice modern look and a smooth ride. The only downside is that they suffer from noisy A/C units, which was mentioned by someone on another thread. On the odd occasion that I travel on the LTS line which I try to avoid, I find the 357's to be rather quiet. They're maybe a little cramped especially during busy times. Can't speak for the other classes though as they're not available for where I need to go.
Mikey C
11 Feb 2013
Personally, I don't have strong opinions either way, it tends to be more down to the interior and seating choices, as both families of trains to me do a decent job
JohnRegular
12 Dec 2016
In my experience in south Hampshire, people consider the Southern 377s to be inferior to SWT's 444s and 450s. And I would agree, although I don't mind the electrostars, they get the job done.
class387
9 Oct 2015
375 vs 450 isn't a fair comparison as most 375s (other than /9s) are 2+2 low density seated, while 450s are high capacity 3+2 units. 375 vs 350/1 would be a better comparison.
Personally I prefer a Desiro as they are smoother and better built, but I definitely prefer an Aventra to the Desiro City.
Agent_Squash
22 Jul 2016
Is it the ironing boards?
5 Jan 2014
The thing that I dislike about the 450s is the lack of lateral spacing between the seats in standard class. When SE were running in and out of Waterloo at Christmas I took the opportunity to travel over the old Eurostar route and found the quality of the interiors of the South eastern services to be much better than any of the SWR stock I have used.
SEClass375
16 Aug 2016
What I have noticed is that a 1st class seats on a class 450 are the same type as the standard 2+2 seats on a class 375
Muzer
3 Feb 2012
Not sure about exactly the same type, but similar perhaps. They're certainly the same as the standard class seats of a 444. As others have said, comparing 450s which were designed more for outer suburban work to 375s which were designed for long-distance work isn't really fair. One could argue about the work 450s actually do not really being outer suburban, but you can blame Stagecoach for that!
class387
9 Oct 2015
No.
SEClass375
16 Aug 2016
The only Desiro I have been on is a 450 unfortunately. Comparing it to only a 375/9 or a 377. There isn't much in it for comfort but the ambience is better on the Electrostar. Anyway, I still prefer an Electrostar.
Muzer
3 Feb 2012
never been on a 700, whats the problem w/ it
In standard class it has the infamous "ironing board" seats (same as on the 387s, some later 377s and the 707s). These are seats that are shaped like ironing boards (hence the name), but they have very little padding. If you're a fan of hard seats you might not mind them, but for everyone else they're awful.
In addition to this, the seating layout inside a 700 is very sparse, and they have considerably fewer seats and more standing space than the trains they replaced (this is due to the anticipated demand for standing space through the Thameslink core). The seats also don't have tables in standard class.
8J
31 Aug 2009
I find the ride quality on Desiros poor compared to Electrostars, however I quite like the 444s for their comfortable interiors.
Class313:)
25 Jan 2018
Barnet
really? how so? Have 2 say tho, GN/GTR shoulda kept some 319s for some services that r more long-distance. Could run them as 12 cars instead of 8.
8J
31 Aug 2009
Well if you take a ride on a fast service from Woking to Waterloo on a 450 and then do the same journey on a 158/159, you'll notice the difference. It's the same with the 185s over the chat moss
