Any suggestions please for the cheapest fare combination for an Adult Off Peak Day Single (or similar) from Edale to Glossop, please? (Travelling afternoon of Saturday 1st August 2009).
Presumably splitting the ticket into Edale-Marple and Marple-Glossop will result in a cheaper overall fare than buying a through Edale-Glossop ticket?
And are there any discounts for this journey for two or more people when travelling together?
Also, what route(s) can be taken for the part of the journey between Marple and Glossop?
Edale to Glossop has only one single fare, the Standard Day Single- Route Any Permitted at £11.50 (non discounted).
Edale to Marple again only has one single fare, the Standard Day Single- Route Any Permitted at £5.50 (non discounted).
Marple to Glossop does however have an Off Peak Day Single- Route Any Permitted (due to it being wholly within the GMPTE area), this is £2.90 (non discounted).
So splitting at Marple is going to be cheaper at £5.50 + £2.90 = £8.40. I would also suggest that this is going to be close to the cheapest option, considering Marple is one stop from the boundary of the GMPTE area and thus you are taking full advantage of the GMPTE subsidisation. Strines is in fact one station closer to Edale and still in the GMPTE area, this would reduce the combination to £5.10 + £3.10 = £8.20, but at the cost of severely reducing your options, as Strines has a significantly lesser service than Marple and has practically no direct trains from Edale.
The Permitted Routes between Marple and Glossop are unfortunately not very abundant due to the fact they have Guide Bridge as a Common Routeing Point. The only permitted route is therefore direct via the shortest distance from the origin to the destination over which a regular scheduled passenger train service operates. No doubling back (passing through the same station twice on a single journey) is allowed.
The Shortest route from Marple to Glossop is as follows:
Distance: 14 miles 58 chains
From Marple
to Romiley,
to Guide Bridge,
to Dinting,
to Glossop.
So your journey from Edale will require you to travel Edale to Romiley, then change for the service from Rose Hill Marple to Guide Bridge and then change again for the service to Glossop.
If you did want to take advantage of the discount by splitting at Strines, this would require you to travel Edale to New Mills Central, then change for the stopping service to Romiley, change again for the service from Rose Hill Marple to Guide Bridge and then finally change for the service to Glossop.
