ECML South disruption - OLE down 09/12
Kilopylae
9 Jan 2018
Uxbridge (ex Devon)
1N29 (1800 London Kings Cross to Edinburgh), which my friend is on, is stuck at a red signal south of Peterborough behind 1D28 (1833 London Kings Cross to Bradford Forster Square)
Edit: Looks like there's a whole queue of trains waiting at red signals stretching back from Grantham. It is slowly moving, e.g. 3J39 just went from being stuck at a red signal to making it to Peterborough.
YorkshireBear
23 Jul 2010
I am on 1D23 been told to expect single line working. Reckon the London Leeds section will take as long as Cologne to London did earlier today.
Trainguy34
29 Apr 2023
Kent
Looks like somethings been turned round at Peterborough, now seeing an "LNER 5CAR" on Traksy aswell as 1S28 - unsure what that's doing but it's 100 mins down however is ages away - not even anywhere near Grantham!
800001
24 Oct 2015
LNER 5 car is a set that was dumped there on Saturday night during disruption .
1S28 is delayed due to OHL issues near Sandy, delayed its journey into London!
Banham7
12 Aug 2020
Lincolnshire
800205 sat at Peterborough 5 (terminated short from 1B90 on 09/12)
800208 sat at Grantham Goods Line (formed as 1Z99 from Lincoln Terrace on 09/12 as a result of 1B91 being cancelled)
Trainguy34
29 Apr 2023
Kent
Wonder if it's going to be a special stop order at Doncaster since 1N94 is scheduled to be 1st stop York?
Mainliner
1 Nov 2010
Northumberland
Heavily laden 1N94 now pulled out of Newark
… and the passengers from 1D81 have got off at Doncaster.
24 Oct 2015
800205 finically moved north tonight as 5F05 21:00 Peterborough to Doncaster depot.
Trainguy34
29 Apr 2023
Kent
2 things:
Where did 1D81 go, now a Lincoln LNER in P3 at Newark.
Why does it look like another Bradford-bound 180 has broke down near Newark?
800001
24 Oct 2015
2 things:
1D81 unit shunted into the sidings at Newark Station.
mm333
28 Aug 2008
53.8331°N 1.7734°W
The 1958 Lumo Edinburgh-Kings Cross is calling at Doncaster. Customers for the cancelled 2045 Leeds-Kings Cross - the last southbound LNER from Leeds - are being advised to board the 2121 Northern stopper to Donny and get the Lumo service.
EdChap
30 Nov 2018
Surely there must be a case now to add extra OHLE supports betwwen existing supports and this should cause less problems.
Nicholas Lewis
9 Aug 2019
If it was high winds that caused the dewirement then might help but if it was component failure in the headspan then what we need is a campaign to change out fatigued components.
ChristopherJ
Repeatedly returning banned member
8 Aug 2005
London, UK
LNER should go back to diesel operation between Peterborough and Doncaster permanently to stop these frequent dewirements on that ECML section.
59CosG95
18 Aug 2013
Beeston (Notts)
Things *seem* to be getting back to normal this morning. A few late departures owing to disrupted staff, but nothing out of the ordinary.
And I suppose Thameslink should as well, on the arguably more heavily trafficked section south of Peterborough?
Most of Peterborough - Doncaster (well, Grantham - Doncaster) is two-track with single-track cantilevers which don't bring the same level of chaos that headspans do when the wires go down (although there are some headspans here & there).
It would be a lot easier in terms of possessions to re-engineer the OLE north of P'boro as you have longer windows of time in which to do the work on Saturday nights; those full 10-hour possessions are a luxury the routes nearer London don't have.
Mainliner
1 Nov 2010
Northumberland
But that wouldn’t have helped last night, when the blockage between Grantham and Newark was caused by a fault on a non-LNER diesel unit…!
As a matter of interest, was the considerable delay due to the time taken to assess the dragging brake issue and give permission for 1D81 to proceed to Newark at reduced speed?
I would add that passengers on the immediately affected 1D81 and 1N94 trains were very patient and good-humoured, despite earlier delays getting to Peterborough, and no doubt this was partly because there was still heat, light, functioning toilets and (at least on 1N94) bottled water being made available.
harz99
14 Jul 2009
I assume 1D81 was the GC 180 that eventually arrived at Sunderland a shade under 3 hours late? Did it carry on in passenger service throughout?
Mainliner
1 Nov 2010
Northumberland
1N94 carried on towards Sunderland after picking up 1D81’s passengers at Newark and dropping them off at Doncaster, although I got off at York.
As mentioned earlier, 1D81 was shunted into a siding at Newark.
23 Nov 2015
How are you doing that with a large proportion of the fleet being electric only?
harz99
14 Jul 2009
Thank you
