ECML major disruption (26/07)
londonmidland
22 Dec 2009
Leicester
Major disruption on the ECML today due to damage to the overhead electric wires in the Hitchin area. Disruption is expected until the end of the day.
Sounds like major damage has occurred, with multiple lines affected. I assume several headspan structures have been affected?
malc-c
1 Dec 2017
Local BBC Radio are reporting problems with overhead wires at Biggleswade in their travel reports
Twingo37175
24 Mar 2019
My better half and eldest son are returning from the big smoke this afternoon, back to Doncaster. Think my eldest lad is probably one of the few pleased around this as it means he can come back via Manchester (seems a grand central 180 can be swapped for a pendolino).
philjo
9 Jun 2009
Had a near miss this morning - I was on the 0654 Cambridge to Brighton service that appears to be the last service that made it off the Cambridge branch before everything stopped. I noticed an Azuma going north on the slow line at Hitchin.
aag2110
18 Jan 2013
Currently at Leeds, meant to be on 11.15 LDS-KGS as far as Stevenage. Staff suggesting either going to Manchester then on to Euston or Sheffield and on to St Pancras & then back out.
Safe to say the platform for the delayed 11.11 XC service via Sheffield is very busy!
Opting for the much quieter if slightly slower 11.39 Leeds-Lincoln via Sheffield Northern service…
OxtedL
Quizmaster
23 Mar 2011
Looking at the positions of stalled trains, it seems there could be two separate issues - one between Stevenage and Hitchin, and one around Biggleswade.
LowLevel
26 Oct 2013
Main problem being the mainly 5 coach EMR trains from Sheffield are far from able to handle the numbers so are reporting full before departure - I'd have gone for Manchester myself!
An_Engineer
14 Feb 2018
Was trying to head Cambridge way this morning (to Meldreth), and anything on the KingsX-Cambridge line going through Hitchin is cancelled as well. Intitially we were told just Peterborough trains were cancelled, though gradually all cambrdige trains were cancelled as well (despite the announcers at Finsbury park being told that Cambridge services were still running, not their fault just bad information).
Trains all the way down to Brighton on Thameslink seem affected (due to originating in Cambridge).
D1537
11 Jul 2019
North Yorkshire
Oddly, LNER have acceptance on EMR, but Hull Trains and Grand Central don't (both have Avanti, Northern and TPE, and GC also have LNWR and XC).
800001
24 Oct 2015
The issue is around the neutral section immediately south of Biggleswade.
1D02 has damaged pan.
1N80 is evacuating customers of 2 stranded GTRs south of Hitchin, both without power.
1D03 returned to Hitchin to detrain.
1S05 retraining at Arseley.
No services south of Peterborough for mainline for remainder of day, also no service to/from Leeds.
Be trying to distribute the customers, so they don’t all head for one route.
Euston reportedly turning customers away due to the volume of them turning up.
LowLevel
26 Oct 2013
They do and have since this morning have ticket accpetance on EMR - someone seems to have gotten confused. There has been a clanger somewhere whereby it was input and messaged out to staff as "accepting Cross Country and TPE tickets due to overhead wire problems at Hitchin".
Cross Country and TPE controls look after the ECML open access operators so someone has crossed their wires and put them rather than Grand Central and Hull Trains.
Twingo37175
24 Mar 2019
Have advised the other half and eldest for Euston, given the joy I can imagine on EMR to Sheffield. Spotted a couple of 11 carriage trains for Manchester, I know that coach U is unreserved on those, is there a second unreserved carriage? Thanks!
Kite159
27 Jan 2014
West of Andover
Normally coach C.
I believe the former FC coach on a refurbished set is also unreserved for Standard class if you get one of the few refurbished units
railfan99
14 Jun 2020
Victoria, Australia
A friend from Australia is on 1B37 (1050 hours Nottingham - London St Pancras) and was only 20 minutes late at Leicester.
He says for what could have been a super disrupted day, this amount of unpunctuality is tolerable as originally he wanted to go on another route.
Apparently there are standees even in first class where he and his wife are seated.
HamworthyGoods
15 Jan 2019
Why aren’t LNER serving Leeds when the issue is South of Peterborough?
Indeed you would expect some sort of Leeds to Donny shuttle as a minimum when they are the main service provider between the two locations.
800001
24 Oct 2015
Purely a presumption, but if they needs to travel to stations up to and including PBO they go via York or Don and change. For London divert them via alternatives.
Otherwise Peterborough becomes inundated with customers for London with no where for them to go.
class 9
18 Nov 2010
There's not enough capacity at Peterborough, also Leeds- London passengers will be using XC to Sheffield, then EMR to St Pancras.
800001
24 Oct 2015
Plus crews will be all to pot now. Leeds crews may now be covering for KGx crews and helping the services to Peterborough, hence why Leeds serviced all binned.
There will be a method in the madness somewhere.
I would love all the armchair experts to go to a control room and run a service in disruption whilst also dealing with stranded and failed trains.
Failed Unit
26 Jan 2009
Central Belt
Could someone refresh my memory, Cambridge - London can't run because it is on the same power section as Biggleswade?
Hopefully this can be altered at some point (in the future of course as it won't be easy) - As it may have helped if they could have kept London - Cambridge open for the sake of diverting some LNER services
AngusH
27 Oct 2012
I would love all the [people who are not controllers] to go to a control room and run a service in disruption whilst also dealing with stranded and failed trains.
I absolutely agree, it would be an excellent idea and give a much better idea of how things go on.
Although instead perhaps the training materials used to train controllers could be released, with example problems from real situations and then people could see how they would get on in the same situation.
TheEdge
29 Nov 2012
Norwich
I was at Wool a few weeks ago when it all went to hell at Weymouth and was stood there with my dad when a non stop service from Dorchester went screaming through the platform. First thing I said to him was "there is a special place in hell for train running controllers who don't issue stop orders!" Then a few minutes latermy insider knowledge kicked in, "actually, to be fair if they stick stop orders in it'll be late to its join at Bournemouth, then it'll be late at Clapham where it'll cause merry hell"
Its frustrating when it happens to you but there is almost always a sensible reason.
I know its not helpful for the intermediate stations but Cambridge passengers can be quite easily plopped onto the GA services to Liverpool Street so its one of those things that would be nice to have but there is at the moment a workable solution.
800001
24 Oct 2015
I believe they have, or at in process of shortening the section isolated, with view to allowing services to run towards Royston.
All trains now evacuated, now the mission to move them all.
800001
24 Oct 2015
If you listen carefully you'll hear every available 37 in the southeast starting up...
Lead to believe OHL power restored, the 2 trains at Hitchin have power, as do the 2 at Arsley.
Failed Unit
26 Jan 2009
Central Belt
True, but LNER at weekends divert via Ely and Cambridge. They don't have the option even if the crew sign the route with the current situation. Likewise Royston / Letchworth are cold be served. But understand the is not going to be fixed quickly.
800001
24 Oct 2015
Up and Down slow at Biggleswade currently being route proved, with aim to opening these shortly.
LNER, look like reinstating trains ex Edinburgh to run all way through to Kings Cross, would expect same soon from London
