Anyone know when they are going to start using the goods lines between Alexandra palace and Finsbury park for passenger trains.
Lots of track-work activity last few months on the goods track between Alexandra palace and Finsbury park.
Not really been hearing much info about this update. What passenger services will be using the lines? FCC ones or more long-distance trains?
Network Rail CP4 plans said:The scheme provides for a 3rd Up passenger line from Alexandra Palace (leading off from the Up Hertford
line to the north of Alexandra Palace station) through to the top of Holloway Bank with associated platform
faces at Alexandra palace and Finsbury Park. This allows some Hertford/Gordon Hill to Moorgate inner
suburban services to operate independently of outer suburban services and Long Distance High Speed
(LDHS) services from Alexandra Palace.
The scheme reduces a constraint in developing ECML timetables thereby allowing an increase in LDHS
services as part of a programme of ECML schemes as identified in the ECML Route Utilisation Strategy.
This programme would allow an increase in services with an improvement in performance even though
more trains would be operating. As the rolling stock on existing franchised LDHS services cannot be
lengthened, additional services are required to support the increased passenger kilometre HLOS metric
for route 8 for longer distance journeys to/from London. In addition, the scheme will also reduce pathing
time in some Up outer suburban and LDHS services approaching Finsbury Park, thereby providing some
improved journey times.
I assume this means that trains using this line wouldn't be able to call at Hornsey or Harringay? Will that mean recasting the services so that only trains to/from Welwyn GC serve Hornsey & Harringay?Network Rail CP4 plans said:The scheme provides for a 3rd Up passenger line from Alexandra Palace (leading off from the Up Hertford line to the north of Alexandra Palace station) through to the top of Holloway Bank with associated platform faces at Alexandra palace and Finsbury Park.
When it mentions LDHS services calling at Alexandra Palace, does that mean the sort of FCC services to Cambridge (if so, semi-fast or fast?) or the East Coast services?InterestingWhen it mentions LDHS services calling at Alexandra Palace, does that mean the sort of FCC services to Cambridge (if so, semi-fast or fast?) or the East Coast services?
I don't think it means that. I'd suggest reading it as if it said:
"This allows some Hertford/Gordon Hill to Moorgate inner suburban services to operate independently (of outer suburban services and Long Distance High Speed (LDHS) services) between Alexandra Palace and Finsbury Park...
Subtle difference - but possibly more accurate?
Perhaps it'll be used for services that already skip Harringay and Hornsey.
