ECML disruption (08/07) inc. points failure at Doncaster & failed train near Huntingdon
8 Feb 2021
Manchester
Yet again the ECML falling over itself. Sat at York station where nothing SB is moving because of a points failure in the North(?) throat of Doncaster station that happened about 0930…
24 Oct 2015
0940 occurred, track circuit showing occupied, has route locked north end of station.
Donny Dave
9 Jul 2005
Doncaster
Looking at Traksy, it is causing a lot of chaos. I can see and hear an XC service sat at South Yorkshire junction waiting for a platform. It has been there for at least 5 mins now.
8 Feb 2021
Manchester
Where are you attempting to travel to?
Not me, my girlfriend is trying to do York to Barnetby, I’m just stood on the platform like a muppet!
Bit scuppered, think her best bet is probably to get the Hull train and try get a lift or a bus over the Humber…
800001
24 Oct 2015
Ah yes, no other option at the moment.
LNER have requested coaches to operate between York and Newark, but that obviously takes time to organise and doesn’t help getting to Barnetby.
Hmm yes, if she needs to travel ASAP that might well be the best bet. If it's just a track circuit issue that might be cleared quite quickly and the backlog will be intense but should start to flow through without too much bother but if the fault is something more serious then this could go on for some time! I would speak to the Northern conductor before boarding about her intensions first though, I don't think a York to Barnetby ticket is valid via Hull (using the bus link to Barton-on-Humber) but I doubt they'll care too much with the disruption.
Highy
26 Feb 2013
N Lincs
Stood on P4 at Donny with the 0944 Leeds. 1026 Leeds has been cancelled, a Great Central train has been through on the 2 way goods and a train from the Hull/ Scunthorpe line has been through on P3.
Some hi Viz clad activity around the down Leeds.
800001
24 Oct 2015
Route had been released, track circuit still showing occupied, but signal can be passed at danger, things **should** be moving immenently.
Signals to be passed at danger been discussed with signaller now but even ignoring massive backlog of trains that invisibly causes delays.
8 Feb 2021
Manchester
I’ll just buy her a ticket to Hull, she’s going to get her Barnetby one back from Delay Repay anyway let’s face it…
edit: with what has been said above I think she’s going to tough it out via Donny
800001
24 Oct 2015
2P06 northern service from Scunthorpe has just been routed into station
Edit- 2Q08 which was on up main has also arrived Doncaster
Highy
26 Feb 2013
N Lincs
We're waiting for 1011 Edinburgh, just had notification that it's been cancelled via Trainline although RTT has it stood outside the station
800001
24 Oct 2015
That’s was altered to go via 2way goods fail to call at Doncaster.
Don’t actually know what is happening with that now
Donny Dave
9 Jul 2005
Doncaster
Bit of a convoluted route, but I think it is York to Hull, the 350 bus to Scunthorpe from stand 10, then depending on what TPE are doing, to Barnetby from there.
800001
24 Oct 2015
Platform 8 is unable to be accessed. Platform 4 needs signals passing at danger, all other routes released ok.
Highy
26 Feb 2013
N Lincs
We've been told to get onto the next Edinburgh which is full and we might have to stand.
Haywain
3 Feb 2013
1D06 has just been routed into platform 8 (per Open Train Times).
Donny Dave
9 Jul 2005
Doncaster
From what I can gather from Traksy, they are trying to get everything through P1 and P3 where they can.
Kumquat
26 Sep 2022
This afternoon Sheffield was reporting "points failure in the Sheffield area" - is Donny in the 'Sheffield area'? Got to Doncaster fine, 16:05 to LKX was mildly delayed (and had platform altered with 2 min notice, only just had time to reach the front half of the train because I checked for updates every couple minutes), but unfortunately a LNER train in front has brake problems, so we've been sitting north of Huntingdon for an hour now.
liamf656
2 Aug 2020
Derby
There was a separate issue affecting platform 1-2 at Sheffield. Some EMR and Northern services were affected
syorksdeano
7 Jan 2011
Sheffield also had signalling issues this morning around the same time as the issues at Doncaster.
Points issues this afternoon at Sheffield
