Ebbsfleet, Monday mornings
BahrainLad
3 Aug 2015
Does anyone travel from Ebbsfleet on Eurostar on a reasonably frequent basis? I am trying to work out the best strategy for catching a Eurostar to Paris on a Monday morning in a couple of weeks.
I could either go
Stratford Int ; St Pancras ; Paris at 0707-0714 then 0755-1117
Stratford Int ; Ebbsfleet ; Paris at 0729-0739 then 0812-1117
i.e. 20 minutes extra in bed if I go in a linear direction rather than turning back in on myself. Or something. Is a 33 minute connection at Ebbsfleet doable when checkin is 30 minutes? The SEHS service heads on to Gravesend so will be arriving at platform 6.
My unfounded impression of Ebbsfleet on a Monday morning is that it should be either completely empty and therefore a breeze, or complete chaos because it's busy and smaller than St. P. Which is it?
eastwestdivide
17 Aug 2009
S Yorks, usually
I was at Ebbsfleet for a Eurostar around 0800 on a Monday morning earlier this month, and it wasn't busy.
I don't know how strict they are with the check-in times, as I'm always ridiculously early for critical connections.
If I had the choice, I'd still choose Ebbsfleet, but get up in time for a train half an hour earlier to get there "just in case". It's a peaceful enough waiting area to while away the time watching trains go past - you can see the NK line in the distance as well as the HS lines.
306024
23 Jan 2013
East Anglia
Tend to agree. I always use Ebbsfleet where possible rather than St Pancras to avoid the crowds at St P. But do allow a bit of insurance over the connection time. High Speed is reliable but for the sake of 15 mins why chance it.
CMS
12 Aug 2009
Buy the ticket from Ebbsfleet and decide on the day what you'll do, as never say never, there could be disruption in one direction. You can check-in with an Ebbsfleet ticket at St Pancras. Ebbsfleet is usually easier as there is rarely more than one train open for check-in at a time, however 33 mins for the 30 min check-in is not safe enough - I noticed recently they are stricter on the check-in times than previously seemingly as when they change the trainset from e320/TMST to the other type, they have to move seats about and reassign people. It has happened to me 4 times in the past 3/4 months.
