East-West Rail (EWR): Oxford-Bletchley construction progress
12LDA28C
14 Oct 2022
Six class 196 units were included in the WMR order for use on EWR and those units are in the process of being introduced into service and bedded-in on WMR routes.
Drivers have been recruited and are in training.
The line will be signed off for route learning some time this year.
Work to increase capacity at Oxford station so that trains can reverse at Hinksey (rather than reversing in the bay platforms) if required is in progress. This will also help with the planned extension to Cowley if that goes ahead.
All this coming together over the next few months, so I would say that this is fairly good long term planning.
Except of course that passenger services should have commenced a month ago in line with the original plan so clearly planning and reality are two different things...
The risk then is of course that there is an unexpected last minute delay in finishing off the civil engineering and you’ve got trained drivers and “millions of pounds worth of new trains sitting doing nothing” for 12 months and, in the case of the drivers possibly jumping ship through boredom.
Then those drivers would be kept occupied driving existing routes, they wouldn't be sat around doing nothing.
vuzzeho
11 Apr 2022
Slightly off-topic question - when the 230s stopped running, why didn't LNWR extend the platforms on the Marston Vale line to take 196s, so they could run on that line while waiting for EWR to run? Then, the 196s would have experience in Bletchley, and driver training would've been done.
It isn’t in LNWR’s remit to extend any platforms. The EWR project would have done that work IF the Bletchley to Bedford part of their overall project had ever been given the funding. At the time the TWA order was approved DfT were still wittering on about a separate mini-TOC to run EWR, the decision for Chiltern to run it was yet to be made. As it is the TWA order included a number of ‘non track’ infrastructure changes between Bletchley and Bedford, including certain platform lengthening, level crossing closures, new bridges etc etc, but nothing has ever started.
Elecman
31 Dec 2013
Lancashire
Not upto LNWR ( think you mean WMT) but Network Rail/EWR but no agreed funding from DFT/Treasury
DavidGrain
29 Dec 2017
The 196s were not available when then the 230s had to be withdrawn because of lack of maintenance capability. The 153s which had previously operated the line were no longer available as they had gone to TfW. Also remember that Marston Vale is a diesel operated line whereas Bletchley is an electric train depot. I don't know if the operator has had to revert to sending the current stock to Tyseley for servicing.
Chiltern drivers will operate the 196s not LNR drivers so driver training will still be necessary.
12LDA28C
14 Oct 2022
Not sure what you mean by this - Bletchley has always been responsible for maintaining the DMUs used on the Marston Vale line, so it's not just an 'electric train depot' by any means.
Whether Chiltern is the preferred operator for the Bletchley-Bedford section of EWR remains to be seen.
JamesT
25 Feb 2015
12LDA28C
14 Oct 2022
Comments on threads about the Marston Vale line previously suggested that the Class 150/153 units were maintained at the Tyseley depot in Birmingham. E.g. https://www.railforums.co.uk/thread...-running-19-02-24.242143/page-19#post-6333588
Light maintenance was done at Bletchley which has been the case with DMUs at least since the days of maintaining first generation units on the MV as well as the Class 115s on the Chilterns. Bletchley even used to do light maintenance on diesel locos in the 1980s.
Nicholas Lewis
9 Aug 2019
Indeed best part of one billion pounds has been spent on the current phase according to last years NAO report so you would expect the DfT ready to make use of the assets as soon as possible. Given they want another 12mths they might as well have wired it up at the same time.
vuzzeho
11 Apr 2022
Do the 196s have SDO? If the platforms are too short, then they could be moved there now and SDO used for the platforms that are too short. (this is all based off the fact that Chiltern hasn't been officially selected yet, and that Bletchley also maintains diesel 150s)
jfowkes
20 Jul 2017
Is wiring it possible in that timeframe? My understanding was that the passive provision for OLE was as minimal as possible. And I doubt any design work has been done...
12LDA28C
14 Oct 2022
Given that who wants another 12 months? The DfT?
It's been well documented and discussed on here why longer trains such as 196s can't be used on the current MV infrastructure, and not just because the platforms can't accommodate them. A small matter of various level crossings and/or protecting signals being fouled for a start...
Nicholas Lewis
9 Aug 2019
Probably not but if there not using the line saves all the aggravation in the future - wishful thinking i know.
Nottingham59
10 Dec 2019
With just 100km round trip off the wires, the MKC - OXF route is perfect for Battery EMUs with a diesel range extender for emergency use.
Northampton
Passive provision is by definition minimal! (Passive provision means not doing things that would make it harder in future, as opposed to the slightly more active 'for but not with' provision where early work is actively done).
AIUI Any bridges that needed to be rebuilt for EWR's spec (e.g. W12) were rebuilt for electrification clearances, but bridges that were clear for the spec were left even if not clear for OLE. I don't know for certain but imagine the signalling is all OLE compatible as that's now standard practice.
Do you think a line is electrified by somebody who just turns up on a Tuesday morning? Number 1 question would be where the power is coming from - the WCML isn't exactly underused and I expect HS2's feeder station isn't anywhere near ready either.
It's frustrating that some of the bridges weren't done (aiui the number requiring work still is small) but actual electrification makes much more sense to wait until it can be fed either from Oxford & Bletchley simultaneously or from the HS2 feeder directly.
Nicholas Lewis
9 Aug 2019
Of course its not going to happen for reasons you rightly cite so was being purely speculative in that 12mths they could have wired it up had they planned the job properly in the first place.
Mag_seven
1 Sep 2014
here to eternity
Another reminder that posts in this thread should be confined to East West Rail Construction Progress
An alternative thread for speculation surrounding the scheme can be found here:
No. Initial service I believe is only planned to be hourly anyway.
It’s shown as half hourly in the approved track access application (TAA) though, which presumably, (bit of a stretch I know), means capacity exists for 2 tph?
You and I discussed this back in April, posts #1603/1604 etc, but other members may not have seen the linked TAA.
DavidGrain
29 Dec 2017
There should be sufficient capacity at the Oxford bay platforms for 2tph as of now - with the possible exception of during the peaks, seldom see P1/2 being used simultaneously.
Actually I have seen both platforms in use at the same time because there is still single line working (unless this has changed recently), the outbound train has to wait for the inbound train to arrive.
12LDA28C
14 Oct 2022
Indeed but just because the capacity exists, does not mean it will be used from the start of service provision.
DavidGrain
29 Dec 2017
I am assuming that 6 x 2 car units mean three trains with two in service and one spare. It is optional then whether the service in the initial stages operates with a 2 car or a 4 car train.
12LDA28C
14 Oct 2022
That seems logical
Surely HS2 have an obligation to restore the Aylesbury Link having severed it at Quainton. However that very likely cannot be enforced until HS2 is completed and we are still talking about mid 2030s for that.
HS2 have just completed bridge beams at Edgcott Road.
Per the text, seems bridges for 5 miles are being made wide enough for the freight line to be reinstated alongside the high speed line
The replacement of a key local road bridge in Buckinghamshire has taken a major step forward after HS2 engineers lifted nine massive steel beams that will form the main structure of the new bridge.
Stretching for 112 metres, the bridge will carry Edgcott Road across the new high-speed railway and an existing freight line, which runs parallel for five miles between the Bucks Railway Centre near Quainton and the village of Calvert.
It is one of 24 HS2 bridges and other structures which are being built wide enough for both sets of tracks to run side by side. Replacing the old, smaller bridge, will allow the currently disused railway to be brought back into use in the future.
The last part of your quoted section from the HS2 article reads as though the main purpose of replacing the “old, smaller bridge” is to allow for the freight line and Aylesbury Link, but it would have to have been rebuilt anyway for HS2 gauge clearance, which must apply to other similar bridges along that section. Isn’t the reinstatement of the freight line to at least the waste handling sidings ‘non optional’ anyway. They make it seem as though it’s still to be decided…
12LDA28C
14 Oct 2022
Indeed it is. And with the track reinstated at 90mph line speed to boot. You don't lay a brand new railway at 30mph line speed, especially when it's on the same formation as HS2!
