East Midlands Franchise 2019-
OrangeJuice
4 Jun 2018
Why does it need to replace Northern's Crewe - Manchester Airport service? I would have thought the intention would be to have extra connectivity per hour to the Airport avoid Piccadilly and not have a regional service wasting time calling at local stations Crewe - Airport.
Whilst I think the additional train to Manchester Airport from Crewe will be very useful I think the capacity between Crewe and Wilmslow will struggle a lot when/if HS2 phase 2a does open to Crewe in 2027
The Ham
6 Jul 2012
Yes, the proposed route would avoid Birmingham, instead going via Crewe, Stoke-on-Trent, Uttoxeter and Derby...
(in all seriousness, I’m at a complete loss to understand why it makes sense to even consider TPE as the operator of such a service!)
The only thing I can think of is that it means that there's not a micro fleet of units being used by another operator (thinking 185's).
Absolutely. I think it was suggested somewhere to truncate the Liverpool-Manchester-Airport-Crewe to release capacity for this service - which of course means there won't be any extra trains between Crewe and the Airport...
Can't see anything going across Crewe between Liverpool and Stoke lines unless and until the Crewe Hub happens. They have enough problems pathing the Manchester-S Wales.
dk1
2 Oct 2009
East Anglia
Just what I was thinking. Last thing Crewe needs is more conflicting moves blocking up the whole shop.
WillPS
18 Nov 2008
About as illogical as EMT then, given the majority of the journey is in the West Midlands. In fact, after leaving Derby it would pretty much immediately leave the East Midlands.
Tomnick
10 Jun 2005
If you look at it purely on the basis of fitting everything into nice appropriately named geographical boxes, then yes, I suppose it is! In terms of actually resourcing it and the locations of existing traincrew depots though, it’d probably fit best with the LNW franchise if not EMT, although the latter has route knowledge for the vast majority already.
Kneedown
29 Dec 2007
Nottinghamshire
Well at least some of the journey is in the East Mids, wheras the route doesn't go anywhere near the Pennines.
Aictos
28 Apr 2009
Does it really matter who operates the routes?
In the latest issue of the excellent Modern Railways, page 13, there is an article which states :
"...For TPE (or East Midlands Trains) a new service from Liverpool to Leicester via Crewe, Stoke-on-Trent, Uttoxeter and Derby is proposed for evaluation along with the extension of EMT's Derby to Crewe service to Manchester Airport.."
Why not think outside the box and instead re-introduce the Birmingham to Lincoln via Leicester service and have Liverpool to Nottingham via Stoke-on-Trent instead of terminating at Derby?
dk1
2 Oct 2009
East Anglia
Doesn't it state that the Liverpool service is going to terminate Leicester? It will reverse in Derby.
Aictos
28 Apr 2009
It does but the Birmingham to Lincoln service really ought to be re-introduced as it used to run under Central Trains, I don't see the point of Liverpool to Leicester myself especially as Crewe is rather busy these days.
Jorge Da Silva
4 Apr 2018
Cleethorpes, North East Lincolnshire
I believe Birmingham is prohibited in the next East Midlanda Franchise so no Birmingham to Lincoln service.
Jorge Da Silva
4 Apr 2018
Which is rather short sighted of the idiots in DfT....
I completely agree. In the consultation it was suggested that the Birmingham to Leicester, Nottingham and Stansted Services should be Transferred to the franchise but despite 60% of the public in favour of the proposals it wasn’t enough to allow transferring and Remapping so it was dropped and meant the prohibition of Birmingham in the next Franchise.
bunnahabhain
8 Jun 2005
I believe it was more the Transport for West Midlands end that helped block the transfer as they wanted the Birmingham to Leicester and Nottingham routes themselves.
Meerkat
14 Jul 2018
Presumably they don’t want another operator at New Street either? Too complicated??
whhistle
30 Dec 2010
So the reason it should be re-introduced is because it used to be a service?
I doubt there will be room at junctions considering TfWM are looking at how a Leicester to Coventry service could work. South Wigston to Nuneaton = plenty of space. South Wigston to Leicester = not so much space without major work of a flyunder (which admittedly has been mooted).
Perhaps giving people of Leicester and Derby a link to Liverpool and Manchester without having to change at Sheffield is the aim?
If TfWM did get the local Birmingham to Leicester route, I wonder whether Cross Country would stop additional trains at the local stations on that line? They've had 100% revenue since taking it on, which would drop to 50% for some stations, 0% for others.
Although I also wonder how it would work with train staff as I believe there is a mixed pattern with the Stansted services, which obviously couldn't continue.
Jorge Da Silva
4 Apr 2018
So the reason it should be re-introduced is because it use to be a service?
Could you just merge the Nottingham-Birmingham and Nottingham-Leicester?
AndyW33
12 Aug 2013
But what Nottingham-Leicester is this? There's an hourly Lincoln-Nottingham-Leicester which calls at all stations between East Midlands Parkway and Leicester, and there are two MML services an hour, continuing to St Pancras from Leicester. There's no free-standing Nottingham-Leicester service at all.
Qwerty133
7 Oct 2012
Leicester/Sheffield
I wouldn't be so sure that there is capacity between Nuneaton and South Wigston. Unless they can find a way to replace the level crossing at Narborough with bridge (which I'd imagine the current buildings do not allow space for) there would be considerable opposition to any more trains through Narborough unless a stop was guaranteed.
Killingworth
30 May 2018
Sheffield
We seem to be drifting away from the East Midlands franchise implementation.
We're still none the wiser on 2 particularly difficult issues.
1. How are HST 125 units to be replaced?
2. When will the Liverpool - Norwich route be remapped? The franchise implies December 2021 when the Hope Valley Capacity Scheme was supposed to be ready, but that's looking increasingly unlikely. It's doubtful forward timetable planning will permit that date when there's no date set for work on the scheme to commence, let alone be completed. It seems certain to run into at least 2022. Remapping may now occur earlier, or be delayed for longer ?
43055
8 Mar 2018
1. I think there is discussion on that to see if they can opperate beyond 2020 at least until a replacement or new stock comes.
Something I would like to see after last Sundays experience is a better Sunday service on the mainline. Maybe 4 per hour from lunchtime with a slow and fast being shared between Nottingham and Derby and Corby?
Kneedown
29 Dec 2007
Nottinghamshire
It's a case, currently, of IF it will be remapped, not when.
whhistle
30 Dec 2010
Doesn't the ITT state (in loose words) that it will be remapped?
I'd have thought HSTs could continue to run in their current guise but stock replacement must be by X date that will be soon into the franchise.
Burgerstahl
9 Nov 2018
It’s intended, but, the ITT states “Provision will be made for East Midlands to continue to operate the service if an agreement with another operator cannot be reached.”
whhistle
30 Dec 2010
*Thanks*
Didn't read and retain all the info :)
Mollman
21 Sep 2016
Preston
I'd take that as a "We don't want EM to operate it, however we don't want to be held to ransom by another operator either".
cactustwirly
10 Apr 2013
For 1 nobody knows, however the HSTs provide a significant proportion of the EM IC services.
So it would be a complete disaster if the HSTs had to be withdrawn before 2020 without a suitable replacement
