East Kilbride/Barrhead electrification updates
apjsco
24 Feb 2024
They’ve been going up and down all morning, a two, a four and a six car. Oddly, they seem quieter than before
Apologies if this has been answered before (this thread is quite long!) - why are they not introducing electric trains before December 2025? Given the infrastructure works are now almost complete, why the 6 month delay?
hexagon789
2 Sep 2016
Testing and training?
Was exactly the same for Barrhead - wired by the middle of the year but no electric trains until December timetable. They did run a VIP trip in November with the Transport Minister aboard IIRC.
Southsider
10 Aug 2015
I recall it being mentioned that there’s not enough EMUs to run the entire service so 156s will be around for a while yet.
GRALISTAIR
11 Apr 2012
Preston Lancs
I note the Fife Electrification project website mentions the introduction of new Battery Electric BEMUS: https://scotlandsrailway.com/projects/fife-electrification
Will they be battery modified existing 385’s or new units?
I suspect but don't know they will be built from scratch - new.
Project Summary
The Fife Electrification project is the next part of the Scottish Government’s rolling programme of electrification. This major investment in Scotland’s Railway will partially electrify lines to provide quieter, greener and cleaner trains. Reducing carbon emissions will not only improve rail’s green credentials, but will make the air cleaner and play a vital part in building a strong, green economy for the future.
Busman84
9 Sep 2019
East Kilbride
Class 380s are suppose to be on the line from December. Somewhere is going to see 380s either taken off the line (4 car Neilston workings), the likes of 6/7 car workings Inverclyde and Ayrshire will be fewer, or 3 cars workings removed from Cathcart Circle, Neilston, Newton and Paisley Canal workings with Class 318,320s been shuffled around from North Clyde/Argyle Lines replacing these workings above but meaning even less 6 car workings.
Also the possibility of 156s remaining on the EK line then on various workings especially peaks if the line is not fully EMU workings.
Whatever way it’s not a win win and rather embarrassing.
Falcon1200
14 Jun 2021
Neilston, East Renfrewshire
If it does prove to be the case that insufficient EMUs to operate the East Kilbride service, for a number of years at least, surely questions are going to be asked about the point of all the expenditure and disruption, up to and including the Scottish Parliament. Has there ever been a case before where a line was electrified without suitable stock ready to benefit from it?
MadMac
13 Jun 2008
Moorpark, CA
I think the simple answer is lack of trains! Also, I believe that the electrification has still to be hooked up at the Busby Junction end.
PaulC1309
27 Nov 2019
Amy chance Scotrail would take 350s tbat are becoming available to solve the EMU shortage? Could they work with 380s since they are similar?
MadMac
13 Jun 2008
Moorpark, CA
Wishaw-Mossend via Holytown was electrified, and the Glasgow-Lanark via Hamilton DMU service was withdrawn at the same time rather than being replicated with EMUs.
OB23Gone
22 Aug 2022
A combination of No passenger on them ie less weight, higher temperatures, a great deal of replacement track and ballast put in. Tampers have been in many times but may only have been doing the new trackwork you might be lucky in that you were near to this new trackwork. Permanent Way guys attending to loose rail clips etc.. NR will be glad of any positive response no doubt
scosutsut
1 Jan 2019
scosutsut
The failure to pick up 321 / 321 Renatus, whether they kept them as 4 car or did the whole 320 conversion thing again looks like an embarrassing own goal frankly.
They are already tight for rolling stock and this just makes it worse and it's years away from getting sorted properly now.
EMU303
24 Aug 2016
With peak hour fares being abolished from September it’s the worst time to be reducing capacity elsewhere in order to get some 380s onto the EK line. Unless there are spare seats on some EMU peak services? Upside is there will be some 156s going spare to beef up some other services.
The longed for updated Decarbonisation Plan still hasn’t been published and so we must be at least 3? years away from new trains being introduced?
OB23Gone
22 Aug 2022
1st Day of driver Training Thur 25 May 2025 Some Pics
takno
Verified Rep - Traksy
New layout is now on Traksy. No routes or signal aspects yet unfortunately, but should still be able to follow the test trains
Southsider
10 Aug 2015
A light blue, single car Sprinter has just past Giffnock heading towards East Kilbride. What’s that likely to be?
OB23Gone
22 Aug 2022
Yes 153376 leaving a cloud of dust as it haired it through Clarkston as it was 25 late. Probably/Line speed and it was hard on the heals of 1 of the Driver Trainers which had taken up it's alloted timing. The only thing was he got held at Busby. Well looking at RTT it was 64 late at Busby and only 37 late at Hairmyres
Make of that what you will!!??
alxndr
3 Apr 2015
I think RTT has got slightly confused unless they were testing time travel abilities. Looks like RTT is displaying the time for some of the return journeys rather than the outward journeys as the times jump back and forth, e.g. passing Clarkston at 1611 (+25), Busby at 1651 (+64) and then Hairmyres at 1628 (+37). It looks like a bit of time was lost at Busby station as 12 minutes was lost between Clarkston and Hairmyres, but this was made up when changing end at East Kilbride, and then the return journey made up 5 minutes by the time it got to Thornliebank and got let out early at Busby Junction.
The exile
31 Mar 2010
Somerset
Although the purpose of the electrification to Mossend would have been freight to the yard rather than anything else.
Falcon1200
14 Jun 2021
From memory, it was essentially an hourly service to/from Lanark alternating between via Hamilton and “direct”, so would have been reasonably patronised.
Interesting. The journey time would to Glasgow would however have been longer via Hamilton, compared to via Bellshill, and Glasgow would have been the major destination?
MadMac
13 Jun 2008
Moorpark, CA
About 20 minutes difference, although it was preferable to waiting another hour. The “Direct” didn’t go via Bellshill and only stopped at Uddingston after Motherwell. Railcar has a 1966 timetable.
hexagon789
2 Sep 2016
Service is back up and running this morning.
Albeit delayed due to signalling problems, which cancelled all the Kilmarnock services for a good 3 hour period.
Similar fault to yesterday and I wondered if related to re-opening the EK branch to normal traffic.
