East Croydon Footbridge
markwo15
21 Mar 2012
The structure seems to be on the move, does anyone know how long it will take to get into place across the six platforms?
markwo15
21 Mar 2012
Seriously, it's enormous!
I hope there will be a video/time lapse of it being moved into position
Waddon
15 Sep 2009
I don't know if anyone knows, but the publicity material connected with this suggests (without being clear) that the subway will be permanently closing once the footbridge is in place?
Bridge was moved into position in stages yesterday and in the early hours of today, with trains running.
Fincra5
6 Jun 2009
Aye I could see it slowly moving across when I was working up to Vic :)
91101
25 Oct 2007
I believe that when HS1 was push launched over the M25, the road remained open too?
jopsuk
13 May 2008
A tedious pedant writes:
HS1 doesn't cross the M25, it passes over (and under) the A282...
pendolino
22 Nov 2010
5m per hour apparently. So 1m in 12 minutes. Or 1.39 cm/sec. I stopped there last night and the movement was just about perceptible.
MidnightFlyer
16 May 2010
I believe it is, at least Southern's latest newsletter say so.
If the subway ramps are properly filled in and the areas properly resurfaced that should improve space on the platforms for waiting passengers.
But as this is the railway they'll probably just be abandoned...
Waddon
15 Sep 2009
Seems a bit pointless permanently closing the subway ramps, it will remove a lot of capacity for moving between platforms. Also I've noticed a bit of a design flaw with the new footbridge, it has a roof all the way to the bottom of the steps, but no roof beyond there onto the platform (unless this is planned for later), on a rainy day like today I think this will undoubtedly result in many people waiting/sitting on the steps, causing congestion for other users
