Easiest way to plan a circular trip?
alexl92
12 Oct 2014
Hi guys,
If I wanted to plan a circuilar trip on service trains e.g. Leeds - Sheffield - Hull - Leeds or similar, which websites will help me best do that? Currently I just find the train I want to start on using RTT, then jump forward to the next location and check what trains go in the direction I want from there after the arrival time.
Is there a better way to do it? I assume the usual journey planners won't help as it's not a logical journey.
Cheers!
_toommm_
8 Jul 2017
South West London
Trainsplit can do what you need. For the example above, you'd enter Leeds to Hull as a return journey, but in the advanced options, you can specify 'via Sheffield' but untick the option for it to be applied to the return journey so that way you'll get more logical Hull to Leeds journeys.
pokemonsuper9
20 Dec 2022
Greater Manchester
Fastjp will help there - same engine as trainsplit but faster since it doesn't query reservations and prices.
It can't do a full circle but put the via points in and it'll take you most of the way.
You can also filter by TOC (e.g. Northern only)
