Earphones snapped in iPad
Manchester77
4 Jun 2012
Manchester
Right so I take my earpods out of my iPad tonight and the end bit stays in. What should I do. I can't use it cos I don't want to tighten the earphone jack please help I'm having withdrawal symptoms from not being able to use it. I've tried all manner of tweesers I just don't know what to do please help please
ATW Alex 101
28 Dec 2010
Ellesmere port
I presume you did this by pulling them out with the wire and not the end bit, I've done it a few times on my laptop, whatever you do in the future do not pull them out with just the wire. As for getting the bit out, I would take it to a very well trusted tech repair shop (not a crappy street stall) or take it to an apple store to get it repaired, which I presume won't come out cheap. Either way it will cost something. You could also try very gently tapping it on a table to try and bring it out or use a strong magnet such as an oid (them things you throw in the air together and they make a noise).
I don't know if gadget insurance will cover this if you have it, if you do you could try that. Good luck!
Bungle73
19 Aug 2011
Kent
Pliers? Is there anything to get a grip off at all?
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
Manchester77:1387595 said:
They don't fit the holes tiny. Ill probs take it the the apple store tomorrow idk
Apple store would be my recommendation!
TP
Muzer
3 Feb 2012
Magnets aren't going to cause any issue with the iPad - it's not all CRTs and floppy disks nowadays, you know ;) - I took someone's iMac apart at one point, the screen is stuck on with magnets (meaning when you tried to put it back together again, the magnetic screws would be very hard to get in without them sticking to the screen magnets!).
But I have doubts you'd be able to extract it with a magnet. Hell, are headphone jacks even magnetic?
If only they were easy to take apart... but of course, Apple would never allow that.
(Disclaimer: my posting here does not in any way mean I'm an Apple fan. I've never owned a modern Apple product and don't intend to!)
Skimble19
12 Dec 2009
Best to take it to an Apple Store, since it involves two Apple products I'm certain they'll sort it.
Class172
Quizmaster
20 Mar 2011
West Country
I would take it to the Apple shop also, or at least an Apple certified retailer.
Using a very small drill bit in between your fingers is actually a very good idea, using it in a hammer drill is not.
It could be done if you found a perfectly sized drill bit (~2.5mm), made a jig to hold the iPad securely in place and a well handled drill (perhaps a pillar drill), but I doubt you'll have access to a DT workshop!
Cab2Cab
12 Jan 2013
Hi,
Have you got any long nose pliers, these have fine ends for gripping if you can get in to get a hold or precision jewelry screwdrivers, these are really fine and strong tipped.
I take the warranty has expired,
Cheers
Manchester77
4 Jun 2012
Manchester
Hi,
Cheers
I don't know it happened to the one I bought this this Christmas (2012) and I got it from amazon so idk if it has one...
Apple store was very helpful, the lady said under no circumstances use the superglue thing but get a Ribena straw and and put it round to form a vacuum and suck. She said it works for her kids.
