Using the return portion of a return ticket, without ever having used (or intending to use) the outward portion, has been discussed here before, see for example https://www.railforums.co.uk/threads/must-i-use-outward-portion-of-ticket.138040/
Then, the forum consensus appeared to be that this was 'OK', despite the 2016 Conditions of Travel saying
which might appear to some to be tighter wording than the earlier Conditions of Carriage
However, I think all those discussions pre-date the widespread popularity of e-tickets, so I wanted to ask:
My particular example, if it matters:
A passenger at VIC London Victoria wanting to take the 20:05 to CCH Chichester might think they should buy the £33.10 off peak day single from the available fares from VIC to CCH - but the return portion of a £20.40 super off peak day return from CCH to VIC would also be valid on exactly the same train. If they buy that return as an e-ticket on their mobile device while at Victoria, will it operate the gates, and raise no eyebrows en route?
12.3 A return Ticket must be used in the correct sequence (you must use the
outward portion of your return Ticket before you use the return portion). The
outward portion of a return Ticket is no longer valid for travel once the return
portion has been used.
17. Using a return ticket
A return ticket (including a two-part return ticket) is only valid for the outward journey
shown on that ticket if the ticket is completely unused. You may not use the outward part
of a return ticket after you have used the return part.
- With an e-ticket return, where the outward portion of a return has not been used (but 'could have been', given timings), will the return portion successfully operate gates?
- Will staff scanning the return portion know that the outward portion has not been used?
- And is there documentary evidence (staff manuals or the like) about whether this activitiy is, in fact, 'OK' or 'not OK' ?
