Dublin Dart and UK rail staff
26 Sep 2011
If I were to hold an International Coupon for Eire - does this allow travel on the Dublin Dart ?
I've scoured the ATOC site and can't see anything.
Thank you
radamfi
29 Oct 2009
Presumably DART would be treated no different to any other train in Ireland as it is run by Irish Rail. Luas may be a different story.
wheeltapper1
4 Mar 2012
Ireland
Hi 158801, I can confirm that your CIE coupons are valid on the DART services but are not valid on the LUAS.
reb0118
Fares Advisor
28 Jan 2010
Bo'ness, West Lothian
Yes, that is correct. I've had no problems on the Dart or any other IE service. As an aside, would the coupon be valid on the bus between Rosslare/Wexford & Waterford that replaces the closed rail line?
MiltyG565
21 Mar 2013
The luas is great though. You should use it if you're in Dublin. It's quite cheap anyway, so i wouldn't even worry about the coupon not working for it.
