Driving well below the speed limit
gabrielhj07
5 May 2022
Herts
Re excessive speed differentials between the outside lane and the one next to it, the blame for any ‘close calls’ involving slower cars pulling out to overtake, at least half the blame should be on the driver that has clearly failed to properly judge the closing speed of the car they’re about to block. Obviously the faster car should be cautious of that, but it isn’t their fault that someone can’t use their mirrors.
typefish
12 Sep 2019
Heaton
I'm calling out a specific poster on this thread who stated that they felt that should be legal (and normal) on British motorways and made the comment about responsible adults.
Well, the UK motorway network prior to 1967 was designed for a cruising speed of 90mph, for contemporary vehicles. Read into that as you wish.
One of the other things they have in Germany is very strict enforcement of "pushing" (assuming it means tailgating) and lane discipline. Regardless of limit changes I don't see how any one reasonable could object to that being introduced here.
I wouldn't say they're that strict at all. You need to be really aggressive to be following a vehicle at less than 0.9 seconds separation distance and frankly, someone driving that close deserves what they get, and whilst I have friends who do drive that closely at times, I am really vocal about telling them they shouldn't.
I'm in two minds on that. I've had to decelerate very quickly from ~245kph to 100kph because of drivers who aren't used to people driving very quickly past them. I've learned you definitely can tell when people are about to pull out on you, and after picking up on how to tell, let's just say that every time I've had a gut feeling someone is about to pull out (and I've started to slow down) I've been proven correct.
Falcon1200
14 Jun 2021
Neilston, East Renfrewshire
Perhaps the driver of the car pulling out is expecting the one they end up blocking to be travelling no faster than 70mph? Going. as some do. much faster than that creates the danger and is entirely and absolutely the speeder's fault.
Egg Centric
6 Oct 2018
Land of the Prince Bishops
By strict I mean they actually enforce that law (I didn't realise it was only 0.9s though, I thought it would have been a more sensible gap). Whereas here you could tailgate a police car and no one would do anything 99% of the time.
You can tell almost all the time but i would consider that too high a closing differential personally, even in Germany. Over here if we have a liberation day in speed limits you would have to be even more cautious for a couple of years and although I won't put a figure on it, I wouldn't have thought more than about 30mph differential between cars would be prudent (HGVs more due to vehicle and driver characteristics as well as their lower speed)
If someone was doing 245km/h in the UK, now, then I would put that as 90% the speeders fault for sure. You won't see police do 150mph past a steam of traffic on a two lane motorway and for good reason.
In Germany I'd go 20%/80% the other way.
lachlan
11 Aug 2019
HS2, in 2010, used figures of (approx) 53 pence per minute for business travellers and 10 pence per minute for leisuire travellers. £31.96 in 2010 pounds
A 200 mile journey, assuming no speed limits, could realistically be done at an average of 100mph, taking 2 hours. At present at current speed limits it can realistically be done at an average of 60mph, taking 3 hours 20 minutes.
For a business traveller then, with no one else in the car and in 2010 pounds, that's £42.60 per journey. Now obviously there will be increased fuel and maintenance costs but we'd still be talking over £20. And that's one way. It would realistically be a return trip and clearly the average number of people in the car is strictly higher than 1.
And that's without considering the extra opportunities it opens up - e.g. 3 1/3 hour journey and back in one day is a slog. 2 hours and suddenly not so much.
And £31.96 in 2010 pounds is as near as makes no difference £50 now.
Realistically though you're not going to hit an average of 100mph when most journeys are made due to congestion, which would be worse than today because as you drive faster you need longer distances between each car.
Egg Centric
6 Oct 2018
Did I mention the vast program of road building I also want? ;)
I think this effect can be over exaggerated though. It's not really commuters it's aimed at, who are the usual source of congestion
Given that the difference between 60 & 50mph over the 1.1m of NSL road is just 13 seconds*, it's not exactly going to make a noticeable difference to users.
We’ll have to disagree there. 13 seconds, twice a day, 5 times a week, 44 weeks a year - that’s nearly 100 minutes of my life a year wasted. On the railway we invest considerable sums of money to save seconds here and there that combine with other schemes to add up, over time, to a rather large benefit to society in terms of time saving.
I drive down the A5183 fairly regularly, doing 36 or 37 mph - might get up to 38 past the old 'Punchbowl' and Bow Bridge. Hope you don't come across me lest I cause too much inconvenience!
I have, more than once, overtaken cars on that stretch when they are driving too slowly. On my racing bike.
If my experience of the southern end of the A1(M) is anything to go by, it makes no difference. See it so often - firstly the brake lights come on, then a second or two later on comes the right hand indicator, followed by the ill-judged move to the right.
Just a complete failure to have any situational awareness whatsoever. To compound their ignorance, it’s very often the self-same people who will make an error, and then start berating others.
As ever, the grid of humanity tends to go high confidence/low ability. If it was socially acceptable to get this subset off the road (and I mean *actually* remove them) then the roads would be a much safer and more pleasant place, though I guess the subset would then start immiserating rail journeys for others instead.
gabrielhj07
5 May 2022
Herts
Which would be a foolish and naive thing to be thinking, as anybody who’s driven on a reasonably clear motorway for more than about 20 seconds will know.
Moreover, this isn’t just a problem for ‘speeding’ cars; I see people pull out on me regularly when I’m doing 70 or less.
As @bramling says, it’s the ‘drivers’ who won’t look beyond the end of their bonnet, nevermind behind them, that cause this problem.
Yep, and saw it again today on the A1(M). Middle lane, catches up to someone, brake lights come on for a couple of seconds, brake lights go off, right indicators comes on, pulls out. To be fair this one did make some effort to put his foot down when pulling out, but again all completely misjudged. Just zero awareness of surroundings.
gabrielhj07
5 May 2022
Herts
Sounds like they didn’t know what indicators are for either. Too many people use them as a signal of action, rather than intention.
It is quite difficult to judge the difference in closing speed between say 80 and 100. Thus anyone who is breaking the law by doing in excess of the speed limit really needs to gracefully accept that people are not going to be taking their law breaking into account and thus ensure they themselves mitigate gracefully (not angrily nor threateningly) for any adverse effects it may cause, and so anticipate the likelihood of such an incident and slow appropriately and maintain correct braking distances for the speed they are illegally doing.
(Sorry, I think it is important to emphasise that driving at high speed is not legal in the UK).
Obviously that is different in Germany where such speeds are legal. It also doesn't mean it's OK to cut people up at very low speeds which is endemic in Milton Keynes!
gabrielhj07
5 May 2022
Herts
This is the heart of the problem - inattentive drivers. The actual speeds involved don’t really matter.
Indigo Soup
17 May 2018
Or indeed to request permission - not using them at all where they feel no 'permission' is required for their manoeuvre.
The exile
31 Mar 2010
Somerset
. Similarly on the Autobahn the majority of folk tend to cruise around 90-95mph. The important thing is there's the option to go quicker when circumstances merit it.
From my experience of unrestricted Autobahnen that’s an overestimate - more like UK motorways before the proliferation of speed cameras.
Krokodil
23 Jan 2023
Wales
I was just walking back from the bus stop. 20mph road, through a village, parked cars and discontinuous footpaths - so pedestrians are ducking in and out of the carriageway.
A van flew down past me at what was probably 30mph. You can tell how much attention he was paying by the fact that his left indicator was on, and had presumably been so for a third of a mile from the main road. Needless to say he did not turn left.
Mat17
17 Aug 2019
Barnsley
I've just followed a car for about a mile with its left indicator going, it was also doing 50mph on a straight and clear 60mph road.
AM9
13 May 2014
St Albans
Its speed and the flashing indicator are not necessarily related in either their cause or impact. Personally, I beleive that an unintended flashing indicator represents a more serious hazard than travelling slightly pess than the maximum speed permitted by law for that road.
Egg Centric
6 Oct 2018
Woohoo something we both agree on :lol:
Purple Train
16 Jul 2022
Despond
It absolutely is not, primarily because of the consequences of a collision, but also because others on the road may not have the skill or reactions to deal with you going that fast. You might not even do anything wrong - it could be a totally unexpected mechanical failure caused by a totally unforeseeable manufacturing defect.
Presumption of guilt is neither here nor there. We want people to stop dying on roads, not to decide who to blame when they do.
Many rural Councils are already doing it progressively with signage anyway. Doing it nationally would save them the cost, allowing it to be spent on other road safety matters or even public transport subsidy.
It would be possible to have a system whereby the driving test was much, much more comprehansive and difficult and would include high level medical tests such as reactions tests, thus only allowing people on the road capable of driving at the kind of speeds you would like to see, as well as prohibiting cycling and bringing in jaywalking laws. However the roads are for safe transport for all, not for a personal race track for people who are (or think they are) capable of driving at very high speed, not to mention the environmental issue of the much higher energy consumption at high speeds.
Therefore, while I'd agree there are some who shouldn't be on the road at all, I would say this opinion is well wide of the mark, and you should simply book a track day (or make a visit to the Nuerburgring Nordschleife) when you want to drive at high speeds, and leave the rest of us to use the roads safely to reach our destinations, which is their purpose.
I think people who think it's appropriate to drive as fast as you are suggesting are the ones who should lose their licence and take the bus, as with the exception of professional racing drivers they almost universally have an elevated view of their own driving capability - and that arrogance is one of the most dangerous things that can be on the road. Fortunately, with the increased prevalence of enforcement, that's more likely than what you would like to see, unless they're very good at spotting yellow boxes.
Totally agree.
How about:
Motorway with hard shoulder: 80mph, but 70mph in case of rain or fog
Motorway without hard shoulder or other dual carriageway: 70mph (or possibly 60, I could be sold on that, with signing up for specific motorway style dual carriageways like the North Wales Expressway).
Single carriageway: 50
Single carriageway without marked centreline: 40
Urban: 30 or 20, I struggle to decide which should be default to be honest. But too much signing up and down is unhelpful as it is distracting, so better to pick one of those and stick to it.
Aside from legally mandated limiters these limits would apply to all vehicles, so there would no longer be bus/van/lorry differentials, thus minimising overtaking on single carriageways which is incredibly dangerous.
The 10 suggestion is probably not sensible in many places, but I could see a sense in having Dutch style "Woonort"/"Auto te gast" zones where cyclists and pedestrians have absolute priority and the car is a guest and needs to drive at the lowest practical speed. In effect the whole thing is a big zebra crossing - kids can run out and drivers must stop, for example. This would only sensibly be within residential cul de sacs and the likes.
I'm a bit late to the party I know, but this is an excellent post and one I fully agree with.
Mat17
17 Aug 2019
Barnsley
They had pulled onto the road ahead of me at a roundabout and thus forgot to cancel their indicator, they had come off of a 30mph road onto a 60mph road. I suspect they hadn't noticed the NSL sign at the roundabout, or didn't understand its meaning, so played it safe at 50mph. The cars in front disappeared from view and a nice queue formed behind them. One wonders what speed they would then do when they came to the 50mph marked area, 50 or 40?
Just this morning I have had two people pull out on me as I was right on them, in both cases having to make an emergency brake and swerve, and in both cases the drivers concerned were completely oblivious to what they had done, in the second case even after I gave her the benefit of my very best industrial language (she pulled out of a side road at abiut 7mph, whilst simultaneously mounting the pavement intending to park).
I was on my bike, wearing HV orange, with a high intensity flashing front light, also shouting rather loudly. Impossible to miss in my opinion.
Peter Sarf
Croydon
As with e.g. the online safety bill, I see them as part of our ever-ratcheting nannying/infantilisation of responsible adults. I believe this trend has corrosive effects both in terms of bringing the law into disrepute (and thus creating scofflaws - might as well be hanged for a sheep as a lamb) as well as interfering with fundamental liberties*.
*The speed limit thing isn't a fundamental liberty, but I'm referring to the overall problem type
Don't worry things have improved. We got rid of the dunking stool, stocks and gallows a long while ago.
BUT
Things like cars and the internet have come along since. These things have new risks and need addressing.
Cars have even got faster and more capable, I do think one reason people drive faster is because their new car feels safer than new cars did 20 or 30 years ago.
Internet pervades our families and outsiders have far more access to our children than fifty years ago,
I've spent many years working with the British public in a variety of industries and I was long since disabused of the notion that most of them were responsible adults.
Some of the irresponsible ones believe what they want to believe, some are just irresponsible, some have lower ability (not a sin) and some are just really stupid.
Coupled with speed enforcement it will reduce. There are not only two groups of people.
I can see that enforcing speed restrictions is easier than judging unsafe driving so it makes sense to detect dangerous driving that way.
Speed within reason doesn't cause that many accidents in and of itself. What it mostly does, though, is make them more severe. With energy being the square of speed it doesn't take much more speed to make collisions vastly more severe.
Someone driving at 40mph is almost certainly safer for themselves and others than someone driving at 60mph. This is slightly affected by the frustration it causes which might result in people doing dangerous overtakes, though.
In my view lower speed leads to less severe accidents. But also lower speed reduces the possibility of accidents. Certainly smaller speed differentials lead to less overtaking accidents.
And, I agree, people have to remember they share the roads with people of varying ability.
Given the numbers of people I experience
(1) pulling out of a side-road when they shouldn’t and then driving at 40 mph or sometimes less
and
(2) on motorways people doing well under 70 mph who change lanes to the right when they shouldn’t
I’m not sure this is the case at all. And in a lot of cases there’s an interesting correlation between people who make these dangerous errors and driving round in poorly maintained vehicles.
I’d more trust the 60 mph person whose focussing on what they’re doing and bothers to maintain their vehicle properly.
For (1) it could be a tired old banger but I think often it is simply someone who has no interest in getting up to the correct speed limit and thinks everyone doing the speed limit is going too fast anyway.
For (2) I tend to assume everyone has the right to overtake. I thus avoid frustration - well until they screw their overtaking manoeuvre up by using their brake lights before indicating. I do not appreciate two lorries taking miles to get past each other though !.
My bold - I suppose it is a judgement error - not really interested in safety so drives dangerously with no need to have a well maintained car.
My late Uncle (a former Police driving instructor) taught me at an early age that there are no unsafe roads. Just unsafe drivers.
Whilst I would be confident at driving safely at 60 on that road, I am also confident that not many other people would be, including most people I would be taking as passengers. I can already hear Mrs Bald Rick shouting at me.
Given that the number of single track roads that are suitable for 60mph is, in my experience of driving all over the country, relatively small, I think a blanket 50 on such roads would be acceptable. This is particularly the case given the significant rise in lesiure cycling on such roads.
Yes, better to have relatively simple rules. Then no doubts.
Judging speed by use of a magnifying mirror can be difficult. Especially as one is not usually devoting most of their attention to something other than what is in front of them !.
BUT =>
I have a theory that a proportion of middle lane cruisers do so because enough faster drivers have not let them out of lane one in the past.
To be fair I think most middle lane cruisers are not thinking. It also amazes me how often I see drivers slow down rather change lane then once slowed down they struggle to get into an over taking lane. The number of times I have seen someone fail to take advantage of the gap I have in front of me that way. It makes a lot more sense if I assume their not good at looking behind.
Lets not forget it is probably a bit complicated for some.
I would say speed has more than one problem. Primarily when things go wrong the bad effects (damage and/or death) are much greater with increased speed. Also increased speed leads to more accidents as it relies on better judgement from all concerned.
I was on my bike, wearing HV orange, with a high intensity flashing front light, also shouting rather loadly. Impossible to miss in my opinion.
One thing I learnt riding a bike (well mainly motorbikes) is that one is invisible in many cases as the vehicle is so narrow. I learnt to anticipate when a likely driver was likely to pull out on me. More recently I have learnt that the cause is that a narrow vehicle is primarily judged as a normally sized vehicle a long way off. It takes a better look/concentration to realise it is a small vehicle that is very much closer. Not fair but I always viewed it as in my best interests to accept the risk to myself.
Brent Goose
31 Jan 2025
Hampshire
Another ‘smart’ motorway journey, another crawl due to a report of an obstruction (or animals or a stranded vehicle, etc) which had long gone, if it existed in the first place.
I’m tempted to ring up the Highways Agency and tell them I spotted Atlantis on the clockwise M25 just before the bridge and see if they put a 50 mph limit on because of that.
Peter Sarf
Croydon
Another ‘smart’ motorway journey, another crawl due to a report of an obstruction (or animals or a stranded vehicle, etc) which had long gone, if it ev existed in the first place.
Im tempted to ring up the Highways Agency and tell them I spotted Atlantis on the clockwise M25 just before the bridge and see if that put a 50 mph limit because of that.
Well, now this gives me an idea. They do have their uses. How about reporting an obstruction on a motorway carriageway that is feeding your planned route. It might reduce the traffic getting on to you chosen route. So for me M40 to A23 could be improved by reporting an obstruction on the M4 either side of and on the approaches to the M25
I suggest this as a person who has encountered several lanes 1 and/or 2 closed events but never seen the obstruction. To be fair - maybe it was an invisible force field. Boy crying wolf springs to mind and I feel more worried about my own safety pootling along at their demanded maximum speed (of often about 40mph) in lane 2 or 3.
I have a great low-tech idea. How about having a continuous strip of hard-ish surface down the left side of each carriageway for people breaking down to move into. We could call it a hard shoulder. Any takers ?.
ExRes
16 Dec 2012
Back in Sussex
I saw a situation a couple of days ago where driving under the speed limit actually avoided an accident, the dog and I were walking along the pavement next to what is these days a high speed (30mph) residential road, there are some laybys which take about 4 cars and a man aged 30s/40s pulled his SUV straight out from the layby with no indication or rearward look, fortunately the car closing up on him was being driven well under 30mph by a 20s/30s man who was so busy playing with a mobile on his lap that he was completely oblivious to what was happening ahead of him, SUV man belatedly realised what he'd done and accelerated, no doubt to above 30mph, saving the unknowing car driver from rear ending him, luckily neither the dog or I needed to see a trauma specialist after witnessing this near disaster
ps I mention the approximate age of the two drivers as most people seem to think that only over 60s are capable of stupidity while behind the wheel
AM9
13 May 2014
St Albans
Most people seem place 'offenders' in 'other age groups' (to themselves of course!). That distances themselves from such incompetence.
Ollie29
14 Apr 2023
Stoke On Trent
If I have time on Sunday I'll take my wife's old car (a 1 litre kia picanto) and video driving it around that bend at 60mph and I promise there will be 0 drama, it'll just be a chilled Sunday drive. No claims of being a driving god or pushing on, anyone could do it.
I'm the furthest thing from some kind of speed crazed lunatic you could possibly be.
Did you have time on Sunday to do this? Just out of interest ;)
