driving side
Phillipimo
5 Jan 2013
Portsmouth
On both the roads and the railways vehicles travel on the left but why do drivers sit on the left in trains and on the right in cars?
I'm assuming there's an obvious answer that will make me feel pretty stupid haha
richw
10 Jun 2010
Liskeard
I'm guessing to do with the majority of signals and markers are on the left hand side of the track?
Total guess working by logic
jopsuk
13 May 2008
Sitting on the offside (right in the UK) of a car helps with judging things such as distance to vehicles on the other side of the road. By being closer to the middle of the road, you get better sight lines round more curves and corners.
bigdelboy
9 Apr 2012
Being on the left would ...
[a] ... if on a steam engine avoid having to look over the boiler to get a better view of trackside signals etc.
[2] ... it is easier to open the window and look at the guard waving his flag ... more seriously MOST platforms are on the left and this could be useful.
I'm not a driver ... i am making suggestions ... GWR may be different ... and i really.
Hmmm ... not sure how authorative but interesting is following link: (seems to say drivers generally on the right pre-1923 ... then tendency was to put them on the left).
http://www.britishrailways.info/TRAIN AND LOCO WORKING.htm
6Gman
1 May 2012
Some were, I believe it caused problems when they were used on other companies lines with relation to signal sighting and so forth.
I believe I'm correct in saying that the GWR was different (as ever) and placed the driver on the rhs. When Standard locos started arriving (lhs for the driver) this was a problem and contributed to the Norton Fitzwarren accident where a driver misread signals.
cj_1985
6 Mar 2010
Lanarkshire
IIRC its worth adding, that thanks to the EU there is a move towards a central seating position...
Whether or not it affects us in a major way remains to be seen... but I know its been common on TGVs for years, and know that most of the locos that have been produced in the last few years have moved to the more central position, with it being expected that other locos will (where they are within a certain age range) probably be fitted with new cab desks when they pass though overhauls.
notadriver
1 Oct 2010
Yep most signals and boards are on the left. In France I believe they do drive on the right over there.
The central seating position would presumably obstruct a through gangway except in the case of certain Dutch and Belgian units which have a central cab that folds away upwards ?
Many companies, notably the GWR, did indeed put the driver on the right in steam days. It is helpful for the fireman to be on the left, because he can then use his right hand to push the shovel into the firebox. Norton Fitzwarren wasn't directly caused by signals being on the wrong side - signals for both the fast and the slow lines were placed to the left of the slows and the driver didn't realise he was reading across one track. But there were other accidents where left vs right hand drive was contributory.
French railways mostly run on the left, a legacy of the first ones having been built by Stephenson and friends. Right hand running was imposed in Alsace and Lorraine during occupation by the Prussians/Germans after the Franco-Prussian war, and continued after these territories were returned to France in 1919.
In most high speed trains the driving position is central, probably because the pointed end and difficulty of making windscreens both tough and large means that any other position would have a much poorer view. These are supposed to be interoperable across Europe so need to have good driver visibility of signs on either side of the track.
Goldfish62
14 Feb 2010
Apart from in the east of the country French trains use the left, like the UK.
The Victoria Line on LU is right hand drive.
Yes, this is because most platforms are on the right.
jopsuk
13 May 2008
Is that actually an EU thing? or a UIC thing for High Speed Interoperability?
Didn't the APT-P have a central driving position (which led to opposition from unions as trains were still double-manned)? That first ran a year before Britain joined the EEC! Pretty sure British engineers would have made APT and HST centrally driven too, if it hadn't been for that.
61653 HTAFC
18 Dec 2012
I remember reading about the prototype HST power cars being blacklisted for a while by drivers' unions because of the central driving position, though I could be misremembering that or it could even be one of the many railway myths!
Eagle
20 Feb 2011
Leamingrad / Blanfrancisco
Actually only a small part of it is right-hand running (between a point south of Highbury and Islington, and immediately south of Warren Street), and that was to make the cross-platform interchange at Euston easier. Of course left- and right-hand running doesn't matter at all when the two lines are in separate tube tunnels.
The Central line also runs on the right through White City.
hairyhandedfool
14 Apr 2008
It also has the benefit of putting the front passenger door beside the path rather than in the middle of the road.
rwebster
4 Aug 2011
This is correct, but is more correctly called right hand running.
What the previous poster suggested was right, in that Victoria drivers physically sit on the right. AFAIK, that's unique on London Underground. As a fully underground line nearly platforms are islands (i.e. doors open on the right) so it it would actually be highly illogical to have the driver sat anywhere else.
A-driver
9 May 2011
I don't think it was the central seat but more the lack of a second seat with a view out of the tiny windscreen which meant that training, route learning and various degraded methods of working requiring a second person would be very difficult.
The new 700 trains for the Thameslink apparently have a central seat with the second man seat behind and slightly to the 'non driver side'. The union have been over to Germany to see a mock up of the train and apparently are happy with the seating layout.
Many trains have a fairly central seat now though, although still slightly to the left. 321 and 365s are fairly central compared to the second mans seat.
As far as DOO trains go I suppose a good reason for the driver being on the left is that most platforms are on the left hand side and so lining up with monitors and mirrors and looking back is much easier. Obviously on new trains with built in monitors or guard worked trains this isn't such an issue.
michael769
9 Oct 2005
The main reason is that it is easier to see oncoming traffic when passing parked cars. Try getting past a bus in a left hand drive car (or a right hand drive on the continent) and you will quickly see why it matters.
Didn't they originally insist on having a second man for high speed running?
Tomnick
10 Jun 2005
The relief line signals were indeed located on the left, but the driver (on the relief line) was instead looking at the main line signals, located to the right of the main line - so there was, as you say, a line (the down main) between the driver and the signals that he was working to, but the signals that he should have been obeying were to his left, and presumably rather less visible to him. His error only became apparent as he approached, at speed, the sand drag at the end of the down relief.
jopsuk
13 May 2008
Ah yes, of course. Done plenty of driving in France and Spain in british vehicles too, but not for years :oops:
As for the Victoria line, looking at the map as far as I can see most stations do indeed have the platforms on the right. The exceptions:
Great Portland Street and Kings Cross St Pancras- island platforms, but switched
Highbury & Islington southbound
Finsbury Park northbound
Seven Sisters centre platform (4)
departing platform 1 at Walthamstow Central or 2 at Brixton
Looking at pictures, Class 390 Pendolinos appear to have an almost-central driving postion with a set back second man?
richw
10 Jun 2010
Liskeard
Whenever we have been to the continent in our car, I have always done the driving, the wife finds herself going to brake in the passenger seat though as sat as passenger in the middle of the road.
61653 HTAFC
18 Dec 2012
I believe the class 73 can be driven from either the left or right seat, though the right controls are more limited and more suited to shunting.
See for example http://www.davidheyscollection.com/page96.htm ... about half way down the very long page.
33s are/were the same, which is why a couple were sent up to Aberdeen in the early days of EWS for use on local trip freights.
Buttsy
20 May 2011
Hanborough
That was also a factor in the blacking of the prototype. In fact, it wasn't until the mid-80s that it was agreed that certain trains travelling over 100mph could be single-manned, hence the 110mph services run on the WCML at that time using 87s in the main. I understand that it was still a requirement at 125mph during that period.
Thanks for correction - I checked the accident report after posting and I thought I'd updated my post but it doesn't seem to have gone through.
jamieP
27 Feb 2012
Most compaines had locos on the right hand side. The origanal A1s were R/H drive before rebuilding. Most Pre LNER locos were also R/H drive.
