MODULE TW1 SECTION 10.1-10.3
10.1 When entering or leaving the driving cab
When you enter a driving cab before starting a journey, or when taking over the train from another driver, you must:
make sure that the DRA is set • reset the DRA only when the platform starting signal has been cleared, or if there is no platform starting signal, when you have authority to start the train.
You must set the DRA when you leave the driving cab at the end of a journey or when another driver is to take over the train
10.2 When stopping at a station platform or at a signal at danger You must set the DRA when your train:
• stops at a station platform where the starting signal is at danger is stopped at any signal at danger.
You must only reset the DRA when:
the signal has cleared you have been given authority to pass the signal at danger you are allowed to pass the signal at danger on your own authority
You may set the DRA before your train stops at the platform.
10.3 When stopping at a station platform where no signal is provided You must set the DRA when your train stops at a station platform after having
• passed a signal displaying a single yellow aspect or a semaphore distant signal at caution the platform • been authorised to pass at danger the signal on the approach to entered the platform under the authority of a position light signal or subsidiary signal.
You must only reset the DRA when you receive the 'ready-to-start' signal
