htwestern
Good afternoon,
On Sunday I'm travelling from Cardiff to Freshford, aiming to arrive at 2pm. The National Rail journey planner shows 2 journeys that arrive around then: one tells me to change at Bristol TM for the Westbury service; the other says to stay on the Cardiff-Salisbury train and double back at Bradford-on-Avon.
I'd prefer to double back via BoA as the section between Bath and there is very scenic, it means I'd have a seat for longer, and a shorter wait for a connection.
However, the National Rail planner also says that the route via BoA doesn't have a valid fare:
I've already bought my ticket in advance, it's an Off-Peak day return valid via Bristol.
I had a look at the Routeing Guide and the only relevant things I could find were Easement 700370:
And the routeing point calculator (with route 00817 via Bristol selected) shows this ticket as valid via Trowbridge but not via Westbury (disallowing the circuitous route via Taunton I guess)
So can anyone please advise me if I would be able to change and double back at Bradford-on-Avon (in both directions) using this ticket? I did try GWR help on Twitter but they kept saying I needed to change at Bristol (which doesn't seem right, I'm almost certain I could change at Bath instead on a through train)
Thanks
Positive Easement - 700370
Customers travelling via Bristol Temple Meads to Freshford, Avoncliff or Bradford On Avon may travel via Bath Spa. This easement applies in both directions.
Thanks
