Doncaster/Wakefield to Cambridge
shires666
5 Feb 2012
A friend of mine wants to travel Doncaster or Wakefield to Cambridge this coming Saturday coming back the same day and at any time of the day.
Is there reasonable splits to be made on this journey?
Also if he were to travel with grand central or hull trains would it be cheaper than east coast? As I believe they sell cheaper on the day returns
maniacmartin
Fares Advisor
15 May 2012
Croydon
There's no need to go all the way into London for this journey. I would change at Peterborough and Ely.
Booking on East Coast's website, current prices:
Advance Doncaster - Peterborough 09:20 departure £7.10
Advance Peterborough - Doncaster 19:23 departure £10.20
Walk-up Off-Peak Day Return Peterborough - Cambridge, route Via Ely £16.60
Total: £33.90
You should of course check that these times match up and you don't have a long wait at Peterborough. Otherwise, there are other APs that are slightly more expensive.
The problem with Grand Central and Hull Trains is that they don't call at Peterborough, so you'd have to go via London with them which would drive up the price
There is also a ticket you could consider, Off-Peak Day Return Peterborough to Cambridge Route Via Hun Busway, at £11.30
I believe this means taking the train to Huntingdon and the guided busway between Huntingdon and Cambridge. It's timetable (Route B) is a bit slim on Sundays though.
Could be interesting, hopefully someone who knows more about it can comment on whether its worth the £5.30 saving
Deerfold
26 Nov 2009
The busway buses are comfortable, pretty new and have free power points and Wifi. It's a bit of trek going that far on them.
If you don't mind sitting on a bus for even longer, you could get the hourly one from Peterborough all the way through, saving another £5.30 and having the freedom to catch any other Stagecoach buses in Cambridgeshire for the day (Day ticket is £6). Main downside is you'd ahve to be on the 1816 coming back or get an additional single on the train from Huntingdon to Peterborough.
John @ home
1 Mar 2008
Your friend should note that Peterborough - Doncaster trains are diverted via Spalding and Lincoln from 1315 this Saturday, adding 60 - 90 minutes to the journey. Alternatively, rail replacement buses will run Peterborough - Grantham - Newark. See this page.
