Does going down the ramp constitute trespass ?
Fawkes Cat
8 May 2017
I'm not sure whether crossing "the line" refers to a painted line on the ground or the railway line,
The version of the sign which I quoted above for poetic reasons makes this clear. If you're able to cross 'the line' by means of the footbridge or subway, it's pretty obvious that it's the railway line that is being referenced.
This also ties up with common sense: the railway will be much more concerned by someone being inappropriately on the permanent way than they will with them being part way down a ramp.
styles
7 Dec 2014
Gwynedd
At the end of a platform though, where there is a line painted before the slope, I'd argue it's ambiguous.
I'm not convinced you could point at other signs which use similar wording which the passenger may never have seen and say it's obvious that "crossing the line" doesn't refer to the line painted right next to the sign.
Stigy
6 Nov 2009
Trespass on the railways is quite different to a lot of scenarios described here about supermarkets, etc.
Trespass in most situations is (or at least starts as) as a civil matter. If somebody leaves their front door open and a randomer walks in, that's a civil matter. The owner can use reasonable force to remove the person, but there's not automatically a criminal offence to report.
Trespass on the railways is a criminal offence. The legislation (British Transport Commssion Act 1949) basically just requires a notice to be present. The older legislation (Railway Regulation Act 1840) can be used to enforce trespass rules also, but it requires wilfulness, and also requires a refusal to leave when asked to do so, so not really good at preventing trespass.
If there's no sign saying it's trespass, then it's not an offence.
I'm not sure whether crossing "the line" refers to a painted line on the ground or the railway line, but given how infrequently they are accompanied by a painted line, I'd be inclined to suggest either it means the railway line, or you could at least mount a defence that you believed it referred to the railway line. If the railways wanted to make it clear, they could word it clearer, as the legislation isn't prescriptive in what wording the sign requires. "Passengers must not pass this point.", being a common alternative and arguably much clearer. If you wanted to get pedantic about the 'passenger' point, "No unauthorised access beyond this point.", perhaps.
Although there has to be a sign, it doesn’t necessarily mean you have to pass said sign in order for trespass to be an offence (otherwise trespass wouldn’t be punishable as an offence at anywhere other than railway stations or some level crossings).
If someone goes on to the tracks from a platform ramp then this is obviously trespass, however, if they just venture past the warning not to trespass but don’t go on to the tracks, I reckon it would be a sticky wicket as far as bringing a prosecution for trespass goes. The law commission rules a few years ago that it wasn’t trespass to jump level crossing barriers when they were down, which to my mind was a quite clear cut case of Traspassing on a Railway, as once the barriers are lowered, that to all intents and purposes becomes part of the railway.
styles
7 Dec 2014
Gwynedd
There's two separate railway trespass offences.
The first is the strict liability offence of passing a sign telling you you'll be trespassing.
The second is the offence which requires 'wilfully' doing so and 'refuse (sic) to quit the same upon request to him made by any officer or agent of the said company'.
Basically, if there is no sign, you don't automatically commit a criminal offence. If a member of staff tells you you're trespassing and you need to leave, and you do so, no criminal offence.
If there is no sign at the end of a platform and I walk down the cess, and nobody stops me, I do not commit a criminal offence. It is trespass, but it's a civil matter.
Fawkes Cat
8 May 2017
You experience may vary, but I have yet to see a line painted across the platform which my be crossed by means of a footbridge/subway.
styles
7 Dec 2014
Gwynedd
The presence of a footbridge/subway is irrelevant to what I'm talking about.
My point is, given a basic station with two platforms, or even one platform, and at the end of the platform before the ramp down there is a sign which says, "Passengers must not cross the line.", exactly posted alongside a painted white line as is often the case, it is ambiguous whether that line is the painted line directly perpendicular to the sign, or the railway line.
I take a fairly keen interest in railways compared to the average person and in all honesty, I would've assumed the painted line was the "line" referred to by the sign.
Stigy
6 Nov 2009
There’s no strict liability offence of trespass in terms of lineside trespass. There’s not two railway trespass offences. The Railway Byelaws make it an offence (still criminal) to essentially trespass (although they’re careful to not use that wording - Byelaw 13), but this is not the same as going on the tracks, and refers to the more common trespass as per the civil version you alluded to.
Trespass on the railway contrary to s.55 of the BTCA 1949 relates to trespassing on railway lines, and this doesn’t require a sign to forbid you from doing so. If you go on to the tracks and you haven’t passed a sign, you most definitely are still committing the offence of trespass, which is a criminal matter.
furnessvale
14 Jul 2015
The legal requirement is for a sign to be displayed at the nearest railway station, although they are often displayed more frequently than that.
In the case of a line like the WCML between Lancaster and Carlisle that is perhaps no bad thing.
styles
7 Dec 2014
Gwynedd
S55 BTCA 1949 doesn't only apply to lines. It applies to lines, sidings, tunnels, embankment cutting 'or similar works' ... 'or any other lands of the Commission in dangerous proximity to any such lines or other works or to any electrical apparatus used for or in connection with the railway'. It's very broad.
S55(3) make is absolutely clear that a notice must be present (and 'renewed' i.e. kept in good condition), otherwise no penalty is due.
With regards to the bylaws, bylaw 13 (unauthorised access) also requires a notice:
No person shall enter or remain on any part of the railway where there is a
notice
(i) prohibiting access; or
(ii) indicating that it is reserved or provided for a specified
category of person only, except where he belongs to that
specified category
Bylaw 12 gives power to staff to instruct passengers on safety grounds, so staff could recall somebody from going down a ramp for example.
Stigy
6 Nov 2009
I know where the BTCA applies, but it’s all areas of operational railway (ie where trains move about). I’ve worked on the railway for 20 years, 15 of which have been enforcing Byelaws, along with other acts including the British Transport Commission Act and have had many successful prosecutions, and issued many Penalty Notices for Disorder for trespassing.
The reference to Byelaws was because I took your previous to indicate you were referring to these in your civil/strict liability comments about signage being present, and I understand there is an absolute requirement for a sign. As has been said, the requirement for signage for railway trespass is broad (at every station) in that it doesn’t have to be passed directly for trespass on a railway to apply. If it did, there’d need to be signage on every single piece of boundary fencing on the UK railway network.
furnessvale
14 Jul 2015
Correct, but as I stated above, that notice must be displayed at the nearest station, which can be many miles away.
The exile
31 Mar 2010
Somerset
Thus presumably being a historical anomaly dating from the days when about the only place you could legitimately cross the railway boundary fence was at a station. (Level crossings having gates which were either closed across the highway or across the railway). The only other place I can think of would be foot crossings - which usually had gates /stiles, often accompanied by a version of the notice in question.
43066
24 Nov 2019
Indeed. Thinking about it from a common sense point of view - someone scaling a line side fence and accessing the tracks isn’t likely to pass a sign - they cannot be everywhere! But clearly they’re still liable to be arrested for railway trespass.
furnessvale
14 Jul 2015
It is a realistic look at the problem. If that was not the law, any trespasser could claim that at the very point he commenced his trespass there was not a sign informing him of the penalty.
In spite of the proliferation of high steel palisade fencing, many miles of railway are easily accessible via five strand post and wire fence for example.
High Dyke
1 Jan 2013
Yellabelly Country
Spot on. I'm aware, of least one station, where the sign about trespass is mounted on the station boundary fence. However, you have to walk passed the sign to access the opposite platform via the foot crossing at that location (no alternative access to the platform). I'm sure that happens in many similar stations.
saismee
20 Oct 2023
From what I've seen and heard, sitting on the edge of a train station platform with your feet over the track isn't considered trespass. It's an incredibly stupid thing to do, and it does become trespass if you refuse to leave when asked, but it's trespass on private property (the TOC in question, not sure about NR-run stations). In cases where there's no fence or sign (no passengers allowed to pass this point), it only becomes trespass (on private property) once asked to leave, and it only becomes trespassing on the railway once you reach the bottom of the platform (assuming it isn't require to enter/exit the station).
I would generally consider it trespassing in any case.
Stigy
6 Nov 2009
I think you’re confusing trespass as a civil matter (refusing to leave when asked for example), with trespass on the railway (criminal). The two are separate offences.
Fawkes Cat
8 May 2017
I think we've done this one before: 'private' doesn't mean 'not the state' - rather it means something like 'not dedicated to use by anyone who feels like it for whatever purpose they want*'. So an NHS hospital is private property and so are army barracks , the Houses of Parliament and Buckingham Palace. Your local Town Hall is private property too.
And the private property' status of Woking Station didn't change yesterday morning: neither did anything else operated by Southwestern.
*I'm happy to accept that this wording can be improved.
saismee
20 Oct 2023
I'm specifically differentiating them in my post.
I think we've done this one before: 'private' doesn't mean 'not the state'...
I don't really know the correct wording, but the difference is just that trespass is different to trespass on the railway. I mean they're both private property, but different rules apply.
20 Dec 2024
Saunaland
Personal experience, for what it's worth:
I was picking up my parents from Dundee, I was early and their train was late. Not being a particular fan of humans, I decided to wander out to the far western end of the platform where there weren't any, and I ended up lying on the ramp enjoying the sunshine. Definitely didn't pass any signs telling me not to.
Before long, two BTP officers showed up. They were far more concerned about me as a suicide risk than as a trespasser. They did ask me if I'd mind moving, because I was "making them nervous". That's something I now take into account when trying to get as far away from people as possible.
Had I said, "Nah, I like it here," and refused to move, would I then have been trespassing?
Fawkes Cat
8 May 2017
Nothing would have changed in whether you were or weren't trespassing. But whether the officers were inclined to enforce the law might have changed - and my feeling is that trespass isn't the only offence that the officers could have used to take action against you. 'Generally being a bit of a nuisance' isn't of itself an offence known to the statute book, but I can imagine that 'refusing a legitimate instruction from a railway officer on railway premises' (i.e. the BTP officers) might have given them enough reason to either move you along or arrest you and take you somewhere they considered safer.
norbitonflyer
24 Mar 2020
SW London
However, (quote) "asking you if you would mind moving" is not an instruction. Not sure it is even a request, just a question, to which the answer might be "yes".
43066
24 Nov 2019
If they’d followed up by instructing you to leave and you’d refuse then you would have been. Alternatively you’d have been refusing to obey a safety instruction from staff members, and of course police officers can also arrest people for their own safety if they consider them to be at risk of self harm etc.
Overall it isn’t a sensible thing to be doing.
In this context it’s an instruction that is phrased as a question initially to be polite (policing by consent etc.).
As a driver if I saw someone lying on a platform ramp I’d be asking the signaller to caution the next train through, because it very much isn’t normal passenger behaviour (I’ve literally never seen this), and I don’t want a colleague to end up having a fatality. Hence it’s very much going to be the sort of thing staff will instruct people not to do (and you are obliged to follow safety instructions, even if they’re phrased as questions for the sake of politeness).
Fawkes Cat
8 May 2017
Leaving aside that an instruction can be wrapped up as a request (what did my Dad mean when he said 'would you like to do the drying up '?) I would imagine that a refusal to move at a request from the BTP would be rapidly followed by an instruction to move.
duffield
31 Jul 2013
East Midlands
I'm absolutely sure that some railway bylaw could be interpreted as giving BTP the power to instruct you to move if you didn't do so when asked.
I believe railway employees have powers along the lines of asking any passenger to move from any particular area of a station, including "public areas" if they consider it necessary for operational or safety reasons, and a person lying on a ramp would certainly be a concern and possible distraction for drivers (for example); a driver approaching, and seeing such a person might feel some manner of incident had occurred or might occur, and that it was prudent to stop short of the ramp and the station and contact the signaller.
Annetts key
13 Feb 2021
West is best
Although a sign saying "Passengers must not cross the line" could be considered ambiguous as to the exact meaning, these signs (or the originally fitted signs) normally predate the white lines.
Further, if there are white lines at the top of the ramp, there are normally painted white lines all along the edge of the platform. Hence if the sign really refers to the white lines, how do any passengers legitimately get on or off a train at the platform?
Having said all that, the next question is, what legitimate reason would a passenger have for being on a ramp (which is not part of a path or access to / from the station, platform or other facility provided for passenger use)?
Therefore, if you want to go anywhere where there is or may be any doubt about the legal status, it's wise to specifically ask permission.
styles
7 Dec 2014
Gwynedd
Not sure that's hugely relevant, particularly for younger people who wouldn't have been around in such times. Even then, I'm not sure we can rely on people remembering that the same wording was used 40 years ago on the same signs, and the lines are more recent.
If there was a sign positioned just before the white line running along the platform, that might have some merit, but usually the white line on the ramp is immediately behind the 'must not cross the line' sign.
Oh of course, I'm in no way advocating walking down the ramps. I will admit that I have trespassed on the railway in my youth far more than I would like to admit, including walking down the ramp and along the tracks to shortcut to my back garden further down the line. Wouldn't dream of it now as an adult.
JKF
29 May 2019
It's the fine of 40 shillings that gets me. I doubt the court would accept £2 on the grounds that that is, in fact, 40 shillings.
The one near where I used to live at Pill Station said forty shillings ‘by order of the King’ which I guess is no longer an anachronism, though it definitely was in the mid 1980s!
