hexagon789
Indeed, they remain capable of 750V dc operation and can still multi with unaltered 73s.They still have the shoes.
So could they pair up a 'normal' 73/9 with a CS 73/9 on the sleeper?Indeed, they remain capable of 750V dc operation and can still multi with unaltered 73s.
Yes, they could. Although the five “Southern” 73/9s are dedicated to NR work.So could they pair up a 'normal' 73/9 with a CS 73/9 on the sleeper?
What's a normal 73/9?So could they pair up a 'normal' 73/9 with a CS 73/9 on the sleeper?
I assume it means 73961-965, ie the Southern based GBRf rebuilds.What's a normal 73/9?
All 73/9s are the re-engined examples, the only thing that differs is the engine(s) used.
Do you mean a 73/1, as in those which remain primarily electric with only the small 600bhp EE engine?
Probably one of the GBRf painted ones (Yes they can) rather than the Network Rail “Minion” twins. And yes, I believe they can still work with their original 73 classmates.What's a normal 73/9?
All 73s can still multi, yes. I just didn't understand "normal" in the context of a 73/9.Probably one of the GBRf painted ones (Yes they can) rather than the Network Rail “Minion” twins. And yes, I believe they can still work with their original 73 classmates.
Thanks. So in theory they could do this to increase the loco pool and avoid the use of 66s.Probably one of the GBRf painted ones (Yes they can) rather than the Network Rail “Minion” twins. And yes, I believe they can still work with their original 73 classmates.
No, the 'standard' 73s don't have enough power, 73961-965 have other committed work, are not set up the same, and so aren't really any better than using a 66. The relevant drivers may not the other types of 73.Thanks. So in theory they could do this to increase the loco pool and avoid the use of 66s.
Unlikely, the unmodified 73s add only 420hp at the rail for 77.5 tonnes of loco.Thanks. So in theory they could do this to increase the loco pool and avoid the use of 66s.
Except Egypt...Why do people get so hung up on this? GBRf know their options and this is the best they can do. You'll not get a 66 for haulage on a timetabled service elsewhere!
Egypt?Except Egypt...
(And Ireland, if you accept cab design differences)
Yes, ENR has forty EMD Series 66, known locally as Class 2124 under the Egyptian numbering system.Egypt?
Ha ha ha!
Thank you! Never new that!Yes, ENR has forty EMD Series 66, known locally as Class 2124 under the Egyptian numbering system.
They are used on passenger trains there, they were ordered for that purpose.
might still have their shoes, in store someplace, but they are not fitted on the bogies.They still have the shoes.
And GabonExcept Egypt...
The Royal Scotsman is another 66 hauled passenger service but you'll need very deep pockets for that.Why do people get so hung up on this? GBRf know their options and this is the best they can do. You'll not get a 66 for haulage on a timetabled service elsewhere!
https://flic.kr/p/2no354Q
And Gabon
Gabon railway concession extended as investors fund expansion
GABON: Sociéte d’Exploitation du Transgabonais’ concession to operate the 650 km railway linking Franceville with the capital Libreville and the port of Owendo has been extended, and a new investor has committed to providing finance and expertise to support a modernisation to increase capacity...www.railwaygazette.com
The bogies are different on the 201s as well.(And Ireland, if you accept cab design differences)
By "timetabled" I mean non-charter.The Royal Scotsman is another 66 hauled passenger service but you'll need very deep pockets for that.
But then they would have had to order new class 66's to replace those planned to be used on the sleeper services, at the time class 73\9 really were the cheapest option.Was there any reason why a small number off 66s couldn't have been ETH fitted for hauling sleeper services? It would surely have been much cheaper than the 73/9 conversions.
I believe it is likely down to how packed the 66 is inside - they already needed to get rid of the dynamic braking from the SD40-2, so ETS would have been unlikely to make the cut. Plus, wouldn't that just be a 67 anyway?Was there any reason why a small number off 66s couldn't have been ETH fitted for hauling sleeper services? It would surely have been much cheaper than the 73/9 conversions.
Well, an ETH class 66 would have two more axles than a 67, which should improve the route availability.I believe it is likely down to how packed the 66 is inside - they already needed to get rid of the dynamic braking from the SD40-2, so ETS would have been unlikely to make the cut. Plus, wouldn't that just be a 67 anyway?
...or use the 67s they have just acquired.Off-the-wall-thought, but if you wanted to replace the 73/9s with something else, equipping some 69s with ETS during their rebuilding might almost make more sense...(a 56 is 125t and 80mph, so slightly lighter and faster than a 66)
But I thought there are only two of those (ex-Colas)?...or use the 67s they have just acquired.
There are only two 67s but a single 73/9 generally copes fine with the Aberdeen trip.But I thought there are only two of those (ex-Colas)?
Is the problem with the 73/9s the train-hauling performance (wheelslip problems etc.), reliability or both?
The FW portion was sped up as the Speed restrictions on various weak bridges were lifted when using the lighter 73s. I'd be surprised if the 67s went up that away again unless in a pinch.There are only two 67s but a single 73/9 generally copes fine with the Aberdeen trip.
However, it still isn't clear / in the public domain what the plan is.
