Does anyone else struggle with GWR and it's Wi-Fi?
cc97
20 Nov 2025
For some reason, GWR's Wi-Fi on their trains has never been very good, you'll connect initially but it drops very quickly and if you do re-connect, more often than not it won't have internet.
Is it because of most of the routes go through countryside or farmland which has no coverage? Or is it specific fleets that have this problem?
On the subject, what is the best region of the railways or company that has the best Wi-Fi?
2 Nov 2023
Kent
In my experience, its only their IETs that have WiFi issues. The rest of the fleet seem to be fine, but their 387s have the best WiFi connectivity. When I rode on one between Bristol and London (mind you, much better than an IET also), the area with the worst connectivity was just after Didcot.
cc97
20 Nov 2025
Well that's a bit of a stinker given IET is their main train for their most important services.
The 158, 165, 166 fleet is very patchy too.
My local journey is between Bradford on Avon and Bath Spa, about 50% of the journey it doesn't connect, or if connected freezes and hangs.
Actually the wifi is virtually non existent (as are mobile signals) in parts of rural Wiltshire, Somerset, Gloucestershire etc.
thejuggler
8 Jan 2016
Regardless of TOC or unit, train wi fi is generally poor. Data connection is far more reliable.
cc97
20 Nov 2025
SWR's Suburban routes are decent, can't speak for the main line services cause I haven't really been on them to say
stuu
2 Sep 2011
It is useless between Taunton and Reading, but so is mobile coverage for a lot of the way too
Ashley Hill
8 Dec 2019
The West Country
GWR WiFi is generally crap which is why its free. However 802101 had a modified WiFi system as discussed here….
Parallel
9 Dec 2013
Between Bradford-on-Avon and Bath is more of a data issue than just a WiFi issue. There is very little mobile signal between these stations.
Recessio
4 Aug 2019
Reading to Gatwick is pretty patchy, especially the stretch between Guildford and Redhill - I'm guessing because it goes through so much open countryside in the Surrey Hills?
Barry169
2 Mar 2024
Llanelli
Yes, on the AT300s. The default is connected, no internet. Works about 20% of the time.
No problems with TFW along the same route.
D6130
12 Jan 2021
West Yorkshire/Tuscany
I think that might be in part because of the speeds it travels at.
I thought that it was more to do with the fact that they use a crappy cheap system whereby the internet is taken from the nearby available mobile phone network, rather than WiFi.
I've never had any problems with the proper WiFi connections on SNCF TGVs or Trenitalia Frecciarossa services travelling at 300 Km/h.
Trainguy34
29 Apr 2023
Kent
Maybe not then, you learn something new every day!
Pete_uk
28 Jan 2017
Stroud, Glos
The onboard wifi can only be connected to the Internet via mobile phone networks.
I wonder if they try to VPN the data back to somewhere else before accessing the internet instead of just via the available phone network? It baffles me how new trains can have such a crubbish system.
* VPN = Virtual Private Network
Annetts key
13 Feb 2021
West is best
Having travelled many sections of the GWR network (as well as on various other services in the same or nearby area), there is no simple clear cut answer.
I've had problems on GWR, TfW and Cross-country. I can't really comment on other operators, as I don't travel on them anywhere near as much.
Unless a train is fitted with a satellite system, on-board Wi-Fi has to use nearby 4G or 5G (where available) mobile masts.
So in countryside areas, in cuttings or tunnels, the signal may be weak or non-existent.
The other problem is that if the train is busy, more people are likely to be trying to use the Wi-Fi at the same time, so the available bandwidth gets shared between them.
How good your own 4G or 5G mobile signal signal is is also affected by the same issues. But if you are using a different provider, your service may be better than that for the train. Or it may be worse. Because not every network uses the same transmitter sites.
As well as the above, sometimes some devices connect, but for some reason the internet connection is not established. I've had it where my pad can't get a internet connection but using the exact same Wi-Fi in the same seat of the same carriage, my 'phone can get the internet via the Wi-Fi...
And then occasionally a train or a coach on a train won't have a working Wi-Fi system.
For GWR, parts of Devon, Cornwall and Somerset most definitely have patchy coverage. Not as bad, but there are smaller areas of patchy coverage elsewhere in countryside areas.
Similarly elsewhere in the country.
In terms of trains, I wouldn't say IETs are any worse than the DMUs that GWR operate. I don't travel on 387s very often, so hard to compare.
RedPostJunc
10 Aug 2021
Andover
Actually the wifi is virtually non existent (as are mobile signals) in parts of rural Wiltshire, Somerset, Gloucestershire etc.Sslight off topic
Slightly off topic - it’s not just the WiFi that is poor on these GWR units. In my experience the associated power and USB points often do not work
Recessio
4 Aug 2019
Often I find if I inform the guard about the sockets and USBs on the 165/166 units, they can reset the breakers and get them working again.
However the Internet is just terrible onboard, though I guess that's the rural routes between Guildford and Gatwick.
mickey
11 Mar 2010
SNCF have installed phone masts along almost all of their LGV network, deliberately and specifically so that TGV services receive a good service, thus enabling people to work effectively. They layer did a study that showed it paid for itself with strong revenue from business customers who knew they could be connected so didn’t drive or fly.
If the UK had similar sensible thinking, we could have done similar along the WCML (along with adding additional tracks for capacity) and saved a fortune on HS2.
