Dodgy expansion joint?
Took this at Woburn Sands earlier (sorry, forgot to post it sooner), it shows a welded rail expansion joint which looks to have dipped somewhat - is it still safe like that or should it be reported (if so how?)
strimmer
29 Jan 2010
Cheers.View attachment 86206
If you see something that you think is a safety issue, you should contact Network Rail. Just Google contact Network Rail.
Supercoss
5 Jun 2016
Gap is on non running edge , any safety concerns call the 24/7 helpline 03457 114 141
It's less the gap (which I believe is normal when the rails are cool) than that one side of it seems to point down from the railhead - or is that normal? I don't usually spend hours staring at expansion joints but it's directly opposite the bench! :)
strimmer
29 Jan 2010
If you're in any doubt, make the call.
