Do routes need special certification to allow steam hauled railtours?
SomeTrainboy
30 Aug 2024
NE Lincs
I'm curious whether to see if routes have a "steam allowed" tick on them! Since I'm sure many routes have never gotten steam since BR days, or at least have had years-long droughts in-between steam being used on railtours.
This or vice versa, steam locomotives need certification to run on certain routes, something more specific than route availability.
Or is it just the railtour operator's decision on what to allocate?
Daniel_P
13 Dec 2020
As long as:
- A locomotive is gauge cleared and meets the line's RA
- There are suitable paths / 'white space' in the WTT
- Is fitted with the necessary safety equipment for the route.
Steam can run anywhere on the network. There's a lot more nuance to it than that but those are the basic three principals.
Northampton
It's the other way round - Steam Locos are cleared for specific routes, rather than routes being cleared for Steam. This is because there can be quite wide ranging differences between classes of locos.
A fair amount of the network does get steam at least once a year, if you include positioning moves, although there will be many routes that don't because they're too busy or can't fit the locos down them.
Steam is not issued permanent route clearance, only a 12-month temporary certificate. In nearly all respects the actual process for requesting and issuing clearance is the same as for any other train.
First the TOC needs to get the loco registered on the Mainline - this is usually for the duration of it's boiler certificate. This part of the process certifies the loco has compatible signalling, data recorders, radio, and other safety equipment. Once it's registered, the Operator submits a request to NR for clearance on specific routes. The gauging (always) and structure engineers (if needed) then assess the routes for size clearance and bridge strength, and will then return a Certificate of Temporary Gauging Authority that lists any restrictions or prohibitions (if required).
Once the CTGA is issued, it can be reused for any subsequent tours until it expires. Tours can run using the authority of multiple CTGAs if required (this is very common). CTGAs are typically returned with a specific loco number on them, but where locos of the same class share the same profile (e.g. the 2 SR Merchant Navy class locos) then CTGA issued for a different loco can be used - the profiles will have been verified as part of the mainline registering process. Black 5s could sometimes be cleared as the class rather than loco, as there's quite a few of them.
There were several locos that had a specific restriction on being only for the Whitby branch, although AIUI they still went through the above process.
So long as the operator allocated a loco that had all necessary clearances and could meet the timings of the tour, they were free to allocate any suitable loco on the day. Was quite common to be asked to time tours at 60mph, to allow flexibility in the case of a 75mph loco failing at short notice.
SomeTrainboy
30 Aug 2024
NE Lincs
Interesting, thank you!
Trainz6013
4 May 2024
Earth
I think I remember reading before that the Durham Coast Line between Sunderland and Pelaw Junction is a complete no-no to steam, as that is where the Tyne & Wear Metro run their trains amongst the regular Northern & freight trains. I think it also said that the Metro thought the steam engine would damage the overhead lines?
ChiefPlanner
6 Sep 2011
Herts
Back in the day - RT issued a list of "permitted routes" for steam - including oddly the Watford DC lines ! - I was advised not to even consider it ! (Bedford - Bletchley was included and it all went badly wrong for delays etc .......for reliability purposes a handy RES 47 was "borrowed" which helped) - we ran an extra for staff and families which went down well.
Recessio
4 Aug 2019
What's particular about the Watford DC that makes it an odd choice?
SomeTrainboy
30 Aug 2024
NE Lincs
Is it owned by RT / NR or TfL / whoever runs Overground?
Seems a bit odd to include it given it runs parallel to the WCML, maybe so in case of disruptions on the day of a railtour, they can run via the DC lines, atleast to Watford Junction.
Northampton
I think it's not quite a full ban - IIRC Steam Engines must not be brought to a stand with the chimney under an insulator, but they can be passed for the line.
AIUI the Insulators for the OLE on the metro are plastic, and so if the chimney is directly below them for a period of time they have a reasonably high risk of damage from the heat.
