DIY House rendering drip bead question
hi2u_uk
26 Apr 2014
I know this is probably the wrong website for this but i thought i would try anyway :D
Can anyone tell from this picture whether a drip bead has been installed under the damp proof course?
Is the next step to apply another coat of rendering and then paint over it ?
If so what sort of Paint would be best and what sort of timescale to do this before damage occurs as its been like this for near 6months now
Many Thanks:D
  • Document2.pdf
Cowley
15 Apr 2016
Devon
Many Thanks:D
I can’t see anything on there? But then I’m only looking at it on my small phone screen.
Is it just standard sand/cement render? Maybe if you could take a photo from underneath the edge and also a photo from further away so it’s possible to see the whole job that’d be quite useful @hi2u_uk. :)
It’s not possible to see the damp proof course in the photos
There is a galvanised metal strip which is the drip bead, but these are supposed to drip clear of the lower brickwork. I have seen the lower section rendered before (usually where it was built with non faced engineering bricks) but it doesn’t look like the top has a slope to take water away (but can’t see clearly from the photo angle)
What I find odd is the render is normally flared out at the bottom so that drips are clear of the lower wall below the damp course.
You certainly don’t want to be building the lower render out any further without a distinct gap where the damp course line is (it looks like the 2 renders run into each other in places which is wrong), But it might just be the photo makes it look like this
hi2u_uk
26 Apr 2014
Thanks for the reply. Im not there at the moment so all i can do is to send the pictures i was sent and enlarge them. The issue is that i thought that the drip beading would be more visible in the pictures , but from the pictures it looks like it hasnt actually been fitted unless it wouldnt be visible to the eye
1651333522322.png:?::?::?:
Thanks i actually thought that the damp course was where the holes in the pictures are
i also thought the drip bead would obviously stick out which is why i was wondering if there was one there but im not 100% sure what a correctly fitted drip bead should look like . If the drip bead is already there then i guess theres nothing more than can be done to make it stick out more ??
Im not sure where you think the two renders are running into each other though :(
