DIY Bedroom Air-Conditioner.
J663738
20 May 2025
Hi, installed this about 3 years ago and it work just fine.
Its just a portable 9600btu air con unit, in the loft, with in line fans and acoustic air ducts.
Two bedrooms run off it no problem, each bedroom can control its own air flow.
I know I could have put in two proper split units, but then you have to get people in and then run pipe outside for the external fan compressor and maybe even planning permission. The cost would be many thousands.
This system runs virtually silent as everything in the loft cushioned to stop vibration.
The remote control goes down a light pipe, intended to be used for model railways, so can be operated from the bedroom!
Mcr Warrior
8 Jan 2009
Looks interesting! Definitely being used for air conditioning, and not for growing, ahem, a certain variety of flowering plant? :rolleyes:
Trackman
28 Feb 2013
Lewisham
Lol, thats what I thought, someone goes into your attic and think there's been a grow going on!
Anyway, sounds like an air-con great set-up
