Ken_Ilworth
- Joined
- 10 Feb 2010
- Messages
- 95
Been lurking a while, now it's time to post. Tried a search, but not successfully found an answer..
I travel frequently from Bletchley down to Croydon via Kensington Olympia (to get the best fare and avoid the tube). Sunday coming (14-Feb'10) there are Engineering works Wembley - Clapham Junction. No problem with that, it has to be done, and on balance Sunday is probably the best day.
Journeycheck advises:
Engineering work starting on 14/02/10 between Wembley Central and
Clapham Junction.
Track improvements and maintenance are taking place from 00:20 on
14/02/10 to 04:00 on 15/02/10 between Wembley Central and Clapham
Junction.
Southern services between Watford Junction and Clapham Junction WILL NOT RUN. Customers travelling to/from stations between Watford Junction and West Brompton are advised to travel via London Victoria using the
following diversionary routes: Watford Junction / Harrow & Wealdstone
London Midland to London Euston, then Victoria Line to Victoria.
Shepherd s Bush Central Line to Notting Hill Gate, then Circle Line to
Victoria. Kensington Olympia / West Brompton District Line to Victoria.
Valid Southern tickets will be accepted on the above diversionary routes
for the duration of the works. As a result some trains may be altered
causing extended journey times. Details of engineering works...
..And in fact there is a replacement bus between Willesden Jn and Clapham Jn though it's not mentioned there.
The formatting doesn't help the readability, but pretty clearly they are saying I should travel London Midland to Euston; then Victoria line to Victoria and then onto Croydon. But it's happened before and of course my Kensington Olympia-routed ticket doesn't operate the barriers and that's when the fun starts. In general National Rail staff at Euston & Victoria are OK and let me through the gate. But tube staff, particularly at Victoria are not helpful. Usually they radio to a supervisor who knows nothing about it and tell me that Southern have no right to put that information on the website.
This time I thought I would ask Southern in advance of Sunday what I could do to make my diversion smoother. After an initial exchange, they replied today:
The last sentence you have copied in your email explains "Valid Southern
tickets will be accepted on the above diversionary routes for the
duration of the works." As your ticket is routed 'Kensington Olympia',
your ticket is not valid on the diversionary routes.
You therefore have two options for this Sunday when travelling from
Wembley Central to Clapham Junction:
Travel via underground from Wembley Central to Willesden Junction,
followed by a rail replacement bus service from Willesden Junction to
Clapham Junction with your current ticket.
Travel via the suggested diversionary routes (Euston/Victoria) and
purchase a valid ticket for this route.
I apologise if our website has mislead you into thinking your ticket is
valid on the diversionary routes this weekend.
I don't buy that reply. Following that logic, their advice for passengers from Kensington Olympia to use District line to Victoria is also rubbish.
Anyway, after such a long post, can any members advise me if the advice from Southern on Journeycheck is wrong and I will indeed need to purchase a 'via London' ticket (or get the bus replacement) or should my 'via KO' ticket be accepted on the tube; If so, how can I make the process of negotiating the barriers smoother? Thanks all..
Clapham Junction.
Junction.
