Distribution on advance- started at next station which was skipped
curtly
10 Feb 2016
Hi,
I tried to catch the 7.07 from birmingham new street at sandwell and dudley but the train did not call there but continued the journey.
i have an advance ticket, i am able to catch the next traim or do i need to purchase a new ticket
thanks
The train ran but you missed it at the origin station printed on it?
No, unfortunately your ticket has no value and you will need to purchase a new one, sorry. Officially you weren't even able to board at Sandwell and Dudley though may have got away with it.
curtly
10 Feb 2016
Thanks
For clarity in case anyone else has a similar question, if the ticket origin was Sandwell and Dudley you could use the next train from there if the train failed to call (or the one after) as that counts as a cancellation. The way I read this however is that the ticket was from New St and the OP attempted to board at S&D which isn't officially allowed even if the train did stop there (though anecdotally only some TOCs care about this - Northern very much does, Avanti probably less so because it wouldn't have been to avoid a higher fare). If I've misunderstood and the ticket had an origin of S&D then I'd head there now and catch the next one and explain to the guard (before boarding) that you were confused what to do in a cancellation and went home then found out.
It does appear from Realtime Trains that said train was diverted and didn't go via Sandwell and Dudley - there's a load of missing reports for that section of line.
I think the original post was edited and reads slightly differently to how it did when I first read it this morning.
curtly
10 Feb 2016
Yes I tried to clarify to answer your question but I don't know if I helped.
You are correct the origin was birmingham new street. For completeness I spoke to the ticket office and explained the situation and offered to buy a new ticket.
They advised to speak to the TM
I explained to the TM the situation
