There was political drama about Scotrail “skip-stopping” a few years ago
All that happened on many routes is they ran ECS to the destination
Not even politicians. Senior managers who haven't worked their way up through the ranks interfering also have this effect.Unintended consequences when politicians interfere with thew railway......
At least the 720s are a bit more nippy than the older 317s so have a better chance to making back some smaller delays.The West Anglia stoppers are always affected by this as well. Hard luck if you’re at the likes of Waltham X, Enfield Lock, Brimsdown etc.
That said, it’s a two track railway with airport expresses etc. to contend with, so must be a nightmare to manage.
I've seen XC at times of large delays skipping Reading. LNER are quite good at running the token trains (Skipton/Bradford FS), even when over an hour late into Leeds.LNER and CrossCountry may have had hard times recently but they hardly seem to do that - in fact LNER I can't recall skip stopping!
Particularly tempting because of the dogleg, I suppose. Northbound, I assume the decision would always be taken before leaving Basingstoke so that passengers for Reading could (albeit reluctantly) alight. And one would hope that passengers at Reading would be told to catch the GWR Oxford fast before the XC service was due, at least if they were lucky enough to have arrived at Reading by then.I've seen XC at times of large delays skipping Reading.
It was running early (-1), not lateElizabeth line skipped Southall today in an apparent attempt to make up one minute of lost time
Realtime Trains | 2332 London Paddington to Hayes & Harlington | 14/11/2022
Real-time train running information for 2332 departure from London Paddington to Hayes & Harlington on 14/11/2022. From Realtime Trains, an independent source of train running info for Great Britain.www.realtimetrains.co.uk
so that won't be the reason.It was running early (-1), not lateso that won't be the reason.
It drives me mad on Merseyrail that if a train is even 5-10 minutes late, they just skip stops.
Countary to popular belief Merseyrail has a lot of pinch points esp in the underground sections. One delayed train can -& has- easily cause multiple delays across the network. Better to inconvenience one set of passengers than a hell of a lot more.
I've noticed with EL services that they occasionally show as having passed a station (as it does in the detailed version of the link you sent) despite having called. I don't know if the relative timings in your example would make that a likely possibility, or whether there were circumstances that led to it actually skipping Southall, such as lighting issues or construction work. But I've seen it happen before.Elizabeth line skipped Southall today in an apparent attempt to make up one minute of lost time
Unless it was a train fault, as the next train called at Southall without issue a couple minutes later heading in the Maidenhead direction.I've noticed with EL services that they occasionally show as having passed a station (as it does in the detailed version of the link you sent) despite having called. I don't know if the relative timings in your example would make that a likely possibility, or whether there were circumstances that led to it actually skipping Southall, such as lighting issues or construction work. But I've seen it happen before.
I don't think that's the usual reason - I've seen it happen at EL stations where there is no possibility of the train stopping over a signal. I've always presumed that it's due to the relatively short dwell times.But then what sort of train fault would allow a train to call at all the other stations but not Southall? Maybe the driver stopped just over the platform signal which confuses the system to think it didn't stop there? [Similar to the old LNER HSTs at Inverkeithing and a couple other stations where RTT reports the train as "not stopping" but when it does]
They might not make up time, but it stopped them losing more time.When I used East Dulwich pre-covid they often used to knock the stops out between Tulse Hill and London Bridge. Train left East Croydon 8 minutes late? Cancel those stops.
What stumped me was these trains would never actually make up any time vs doing the booked calls because of conflictions and clashes with the Overground, begging the question of what the point was.
I've had Elizabeth line services skip stops with as little as four minutes of delays. A few have definitely left Heathrow 4 minutes late and skipped all the intermediate stops between Heathrow and Paddington, getting there 15 minutes earlyI've noticed with EL services that they occasionally show as having passed a station (as it does in the detailed version of the link you sent) despite having called. I don't know if the relative timings in your example would make that a likely possibility, or whether there were circumstances that led to it actually skipping Southall, such as lighting issues or construction work. But I've seen it happen before.
I don't know. Everything it's happened I've been at Hayes. Seen the train go flying past me with passengers on board. Checked real time trains and it's skipped every stop to Paddington arriving 15 minutes earlyWhat happened at Paddington, did the trains stand until their booked departure time and so delay everything behind them?
Far-fetched suggestion: could it have run express due to a cancelled Heathrow Express?I don't know. Everything it's happened I've been at Hayes. Seen the train go flying past me with passengers on board. Checked real time trains and it's skipped every stop to Paddington arriving 15 minutes early
Are you certain you were looking at the right train? You claimed that they skipped a stop to make up a minute of delay in post 41 - which to be honest was nonsense.I don't know. Everything it's happened I've been at Hayes. Seen the train go flying past me with passengers on board. Checked real time trains and it's skipped every stop to Paddington arriving 15 minutes early
No I'm talking about separate incidents..I didn't witness the 1 minute skip stopping at Southall (except seeing the train come in at Hayes)Are you certain you were looking at the right train? You claimed that they skipped a stop to make up a minute of delay in post 41 - which to be honest was nonsense.
One part of the network where you might get a good skip stop is on Thameslink
