Disruption between Glasgow and Motherwell (27/12/24)
Peter0124
20 Nov 2016
I noticed on the signal map that trains were at a stand at various points between Motherwell and Glasgow Central.
My train I'm currently on cross-border seems to have been the last one to pass through the affected area. Anyone know whats up?
hexagon789
2 Sep 2016
OLE damage somewhere near Newton.
GB&K Joint
9 Aug 2020
Network Rail Scotland is reporting damage to overhead wires near Newton.
Guard86
14 Nov 2020
Manchester
Alot of damage to train pan and possibility of OHLE damage from Uddingston to Eglington street tunnels.
hexagon789
2 Sep 2016
Whoops, apologies, saw 1S39 sat still at a red automatic signal with nothing in front, assumed that was the culprit. I’ll check harder next time!
Easily done, I believe 1Y77 has been dragged away from the scene of the incident and looks like the rescue loco or unit is running round it, presumably to drag it away to the depot or a siding to be parked up.
Peter0124
20 Nov 2016
OHL damage is about 250 metres east of Newton station on the WCML fast lines according to this picture. Atleast the Hamilton line through the station will be open to diversions till this is fixed. There is also a Network Rail helicopter inspecting the area.
Elecman
31 Dec 2013
Lancashire
Avanti have thrown the towel in again North of Preston issuing a DoNoT Travel notice about 2 hours ago
Guard86
14 Nov 2020
Manchester
It's still in situ. The rescue unit was a DMU for evac of passengers. Will probably be dragged away after close of service by another 6 car DMU.
There's also damage are the polmadie area according to their socials.
thealexweb
5 Jan 2014
What’s Avanti’s rationale for this? Transpennine has provisions in place to facilitate divert but Avanti cannot/will not?
Peter0124
20 Nov 2016
The problem is Avanti can't divert via Whifflet due to clearance problems with the 390 IIRC, therefore only TPE can. I also reckon the crew displacement / stock being trapped north has caused a ripple effect.
For example the last FOUR Preston to Glasgow trains are cancelled I think. Only option is Edinburgh and across.
Class15
30 Dec 2021
North London or Mildmay line
A few ran via Hamilton Central and Holytown. Why can’t everything do this?
MadCommuter
4 Oct 2010
I know this is the standard response but Preston is about 175 miles from the incident. Farcical how they are allowed to do this.
Aaron_TTL
9 Jun 2022
Wonder where the 390's are going from Preston after detraining.. Would be even more amusing if they went back up to Polmadie
hexagon789
2 Sep 2016
Is it more to do with crew changes there than anything else?
Route knowledge.
Certainly 1S69 was terminated at Preston because the booked driver didn't sign the diversion; 1M20 back was cancelled directly as a result.
Some of the other cancellations may have been for the same reason.
SC318250
4 Jun 2011
Newton to Burnside was not available from early evening due to a block to repair the overheads
507020
23 May 2021
Southport
I was on 1S74 16:12 Liverpool Lime Street to Glasgow Central throughout, with in a rare occurrence for me a seat reservation. This is TPE’s route retention via Holytown, Whifflet and Carmyle, so actually ran as booked, with incredible levels of overcrowding from Preston as an entire cancelled Pendolino worth of passengers boarded in addition to an already heavy loading from Lime Street.
Only a few minutes late being put behind 1S75 16:21 Manchester Piccadilly - Edinburgh, but didn’t miss the connection at Oxenholme and only 1 other TPE service made it through via Whifflet for the night, 1S81 17:04 Manchester Airport to Glasgow Central.
Avanti was already running a reduced service with 1tph to Glasgow Central diverted via Castlefield due to the Crewe blockade, which didn’t help things. Overall a very good choice of service from me having booked it on 18 October for tonight.
