Hello All,
Just wanted to check if I'm missing something here.
(From http://www.disabledpersons-railcard.co.uk/what-is-a-disabled-persons-railcard)
However, elsewhere on the site:
http://www.disabledpersons-railcard.co.uk/travelling-by-rail/other-concessionary-discounts
Am I reading this correctly, in that if you have a valid Certificate of Visual Impairment, (which entitles you to a DPRC), then it's cheaper to present the CVI than the DPRC on a Standard Anytime Day Return?
Initially I thought that it was a case of without a railcard, only the disabled person would receive a discount, hence it's cheaper to have a railcard. But it specifically states:
I'm sure I'm simply missing something, but can someone point out what it is?
Thank you.
The Disabled Persons Railcard allows you to get 1/3 off most rail fares throughout Great Britain. If you're travelling with an adult companion they also can get 1/3 off their rail fare - so you can save money for your friends too!
Other discounted fares for disabled people who do not have a Railcard
There are other concessionary discounts on fares available for visually-impaired people or wheelchair users who do not have a Disabled Persons Railcard.
Ticket type
Discount on adult fare
First Class / Standard Anytime Singles or Returns - 34% off
First Class / Standard Anytime Day Single - 34% off
First Class / Standard Anytime Day Return - 50% off
If you are registered as blind or visually impaired and you are travelling with another person, the above concessionary discounts on fares apply for both you and your companion.
Thank you.
