Direct train "always a valid route"...........
father_jack
26 Jan 2010
Just a quickie.
The routing guide provides for the above.
However this week there is a block Tiverton Parkway to Taunton with a 2 hourly train going via Yeovil Junction, leaving Exeter St Davids, missing out Tiverton and Taunton with Castle Cary next stop. Exeter to London Terminal tickets are routed "via Honiton" or "via Taunton". The twitter operator on GWR has told someone they have to go to Tiverton and get a bus to Taunton and then get a train as a "via Taunton" ticket is held !!! Notwithstanding the fact that there is more than likely an easement anyway, does a geographical routing printed on a ticket still over ride the direct train rule ?
furlong
28 Mar 2013
Reading
It's poorly worded but I'd argue this covers it:
Any through train diverted from its usual route will count as a permitted route between the stations it is normally scheduled to call at.
Romilly
5 Nov 2013
The following come from the Easements section of the Routeing Guide:
300227 Journeys routed Taunton may travel via Yeovil Junction. This easement applies in both directions. Fare route
700794 Due to engineering works between 12/06/2018 and 14/06/2018, customers travelling on route ' VIA TAUNTON' may travel via Castle Cary. Fare route
Paul Kelly
Verified Rep - BR Fares
16 Apr 2010
Reading
It doesn't override it but it applies in addition - fare routes are not really part of the routeing guide; they apply separately.
Some booking websites will show a note when a fare route easement contradicts the printed route description, in order to make it clearer, e.g. see attached screenshot from trainscanbecheaper.info on one of the diverted trains. (Pedantic side note: you could argue in that using the old-style "VIA TAUNTON" description, rather than the new-style "Valid only for travel via (changing trains or passing through) Taunton." the text of the fare route easement itself isn't compliant with the accreditation rules requiring the new style everywhere!)
Paul Kelly
16 Apr 2010
Reading
Does this mean that a "via Honiton" ticket will thus be valid on the diverted train?
Yes it will be.
Indeed it's valid, but you won't be able to get it to show in an online journey planner because the electronic data they must use contains a hidden restriction to say a journey on a VIA HONITON fare may not go via Castle Cary.
bb21
Emeritus Moderator
4 Feb 2010
According to a GWR briefing document, there is no fares easement for Via Honiton tickets on non-stop trains between Exeter and Reading, only those calling at Honiton, Axminster or Yeovil Junction.
I can see some forumites already rubbing their hands with glee.
221129
21 Mar 2011
Sunny Scotland
Surely if the train goes Via Honiton it is valid?
Mag_seven
1 Sep 2014
here to eternity
My logic would be if a "via Taunton" ticket is valid via Taunton regardless of whether the train calls there or not (some GWR services pass through Taunton without stopping), then surely the same principle would apply to a "via Honiton" ticket?
embers25
16 Jul 2009
I believe the reason is because if they permit this then route Honiton tickets would be allowed any day the sleeper goes that way..which technically they should be anyway but GWR dispute!
ForTheLoveOf
7 Oct 2017
GWR don't permit passengers to use that entirely valid ticket merely because they don't price it (but rather their sister company SWR does)? Wow!
Deafdoggie
29 Sep 2016
But as the train doesn't call anywhere on that route when diverted, how would a passenger know anyway?
Deafdoggie
29 Sep 2016
I don't think Google Maps tells you which way a train runs. And websites like Opentrain Times or RTT are only really know by enthusiasts, who know the way the train goes anyway, and what tickets are valid! But as, technically at least, the sleeper requires a reservation for both seats and berths, you'd have to get someone to issue a reservation, and the tickets "via Honiton" are not offered on it
A Challenge
24 Sep 2016
Couldn't you go for a ticket office and ask for a reservation for the sleeper anyway?
A Challenge
24 Sep 2016
Ask a ticket office that knows its diverted or just say 'I don't have the ticket'!
bb21
Emeritus Moderator
4 Feb 2010
Officially ticket offices should not be issuing reservations without a ticket.
If the train goes via Honiton, then " via Honiton" tickets are valid.
Booking systems might not be able to show them as valid, due to electronic restrictions which do not in any way affect the contract between customer and rail companies, but irrespective of that, they are valid. It doesn't matter what any member of GWR staff says; they cannot remove that validity.
If the train would normally go via Taunton, and is diverted via Honiton instead, then "via Taunton" tickets are also valid.
Again, there may be occasions been booking engines aren't able to show them as valid, such as if an easement has not (yet) been entered into the system.
If anyone is wrongly charged a change of route excess fare, this would be evidence of a breach of contract by the relevant company who charged thr excess fare.
MarlowDonkey
4 Apr 2013
Reading tickets on the other hand are routed "via Honiton" or "any permitted". At the risk of the journey taking forever it can be a useful money saver to use a via Honiton ticket as the Network card discounts are valid on the old LSWR route, given that British Rail partially reclassified Exeter as part of the south east.
via Taunton is a proxy for GWR and via Honiton a proxy for SWR. You could use Cross Country as far as Bristol, so that's not excluded with the geographic restriction.
It would be nonsense if an Exeter to London ticket intended for travel on GWR ceased to be valid because a GWR train was diverted.
