Dinas a Sir Abertawe
Butts
16 Jan 2011
Stirlingshire
City and County of Swansea ....
I always used to be fascinated by the signs on the M4 as I approached this area of South Wales - looking forward to the only 24 Hour Little Chef I was aware of in the UK, at the then Granada Services.
Are there any other instances of a City and County being one and the same in the UK - I have a feeling Newport may have had the same elevated status.
Why is Swansea a City and County ?
transmanche
27 Feb 2011
It was quite common in the past - a County Corporate.
Over time; I believe what elsewhere would be called a 'County Borough' would be called 'a City and a County' if the place held city status.
In England, what used to be called 'County Boroughs' are now called 'Unitary Authorities' - whereas the 'old' name still exists in Wales; e.g. Wrexham County Borough.
Butts
16 Jan 2011
Stirlingshire
That is interesting but Wrexham Council Homepage does not call itself City and County of Wrexham nor does Bristol call itself City and County of Bristol.I do not believe the roadsigns say it either.
Eagle
20 Feb 2011
Leamingrad / Blanfrancisco
Well Wrexham isn't a city, it's just a borough.
With regards to Bristol I'm not sure, although the relevant authority is called simply Bristol City Council the same is true of the three Welsh city councils.
transmanche
27 Feb 2011
No. Because (as I said) it's Wrexham County Borough! And that's what it puts on the road sign.
Probably because (as I said) the term County Borough is not used in England any more. But 'City Council' is allowed to be used as part of the name of an authority with city status.
In a similar fashion, the local authority for Newcastle calls itself 'Newcastle City Council'. But until 1973, 'Newcastle Corporation' was used as the day-to-day name, with 'City and County of Newcastle' as the 'formal' name. However, the area covered by the current city council is much larger then the original 'City & County'.
Greenback
Emeritus Moderator
9 Aug 2009
Llanelli
Because it is special ;)
Seriously, it's just down to the historical reorganisations of local government between 1974 (prior to which I think Swansea was a County Borough with its own police force) and 1996.
