Different off peak return fare prices for same route?
enginedin
15 Dec 2020
Travelling from Haymarket to Manchester (outbound weekend, return on a weekday within the same week), two different different off-peak returns are offered:
£77.60 Off-Peak Return (Avanti &northern)
£104.70 Off-Peak Return (Via Carlisle)
Given that for the "Avanti & northern" route you'd have to travel via Carlisle, what's the rationale / reason for the difference in price? TheTrainLine lists both fares as being "TB"
TPE set the "via Carlisle" fare and operate the direct services, so most people will want to use them. Therefore Avanti & Northern have come together to offer a cheaper fare if you stick to their services. It's a fairly common situation on routes with multiple operators.
Mcr Warrior
8 Jan 2009
The £77.60 fare can’t be used on TPE
Which effectively halves the number of direct services you can use between Haymarket and Carlisle. Presumably the £77.60 fare can't be used with Scotrail either, travelling via Glasgow QS/Cen?
jfollows
26 Feb 2011
Wilmslow
Agreed, map EG would allow that route for an “any permitted” ticket (EG + MG for Edinburgh-Manchester.
jfollows
26 Feb 2011
Wilmslow
Including any flexible/semi-flexible route "via Carlisle" tickets?
Yes, with a “via Carlisle” ticket you can do a “split route” check and look up Edinburgh-Carlisle and Carlisle-Manchester separately, and Edinburgh-Carlisle is valid via Glasgow with map EG. It also happens that Edinburgh-Manchester is valid EG+MG so you get it both ways, in the latter case with the constraint that you have to go via Carlisle, but that’s not a major issue.
