Differences between Class 150s
M60lad
31 May 2011
This might have been covered before although I'm not too sure so I'll ask anyway, Have 150/1 and 150/2s got different engines or gearbox's fitted as they sound different to each other
Old Hill Bank
6 Mar 2010
Kidderminster
Both have the same engines and transmissions but I think the /2s have better electrical systems attached.
driver9000
13 Jan 2008
The 150/2 has 2 alternators while the 150/1 has 1 alternator not sure of that makes a difference. I can't say I've ever noticed much of a difference to be honest.
Old Hill Bank
6 Mar 2010
Kidderminster
The /2s always seemed a fraction quieter in the passenger compartment to me when we had them on our route. More to do with the construction design than anythig else I suspect. Sorry meant to say less noisey!!!!!
24 Jul 2011
I think that the 150/2s do sound slightly different, and I agree that some did seem less noisy. The best units were the Ex Anglia units; shame they had to go. All seems an age ago now with the 172s!
Class172
Quizmaster
20 Mar 2011
West Country
I never really noticed much of a difference to be honest. If the two sub-classes have different numbers of alternators, how many do the 150/0s have?
Old Hill Bank
6 Mar 2010
Kidderminster
We gained the Anglia ones from the flatlands of East Anglia where the engines and transmissions would have had a much easer life unlike the thrashing anthing on the Snow Hill Lines will get, so they will have arrived in better nick than the stuff aleady in use on the route. No dig at the good Maintenance staff at TYS.
BestWestern
6 Feb 2011
I must say I've never noticed, and I've worked and travelled on plenty of examples of both. In my experience they're generally so noisy and rattly it would be impossible to tell if there were any minor differences in 'noisyness' between the two. The level of noise on any given journey varies considerably depending on a number of things; whether the windows are open and if so how many, how rattly the doors are at speed on a particular car, how hard the unit is being driven, how well maintained it is and so on. But they share the same mechanical kit, bodyshell and bogies, so it's tricky to see where any extra noise output would come from? Indeed, if a /2 has an additinal alternator one might even expect marginally more noise to be apparent from those in some cases?!
Beveridges
8 Sep 2010
BLACKPOOL
150/2 has two smaller alternators than the large one under the 150/1.
Both Units have extremely loud, thunderous engines. I can't say that I have noticed that one is less noisy than the other.
There are many differences between 150/1 & 150/2 but they both have the same engine.
The engine noise on both sub classes is tremendous, as mentioned already.
It's one of the very few advantages of the much quieter 225hp Cummins engined Pacers.
When fuelling these things on NH the noise level at ground level is tremendous!!!
24 Jul 2011
I agree about the level of noise; when all the windows were open and going down to Worcester, it was deafening. On a joking side, one similarity between both sub classes was was the ability for the gangway doors to magically open at any point. 150012 had no handle on one door and just shut and opened every station!
O L Leigh
20 Jan 2006
In the cab with the paper
Don't believe it. They may not have had many hills to climb but that doesn't mean they weren't thrashed. They certainly got a good ragging across the Fens when they worked the Ipswich-Peterborough trip.
Maybe it's just that Clown Point knew how to look after them properly whereas Tyseley just kept shoving them out into service on a wing and a prayer and hoped that not too many of them went pop before they were next on the factory for exam.
O L Leigh
Helvellyn
28 Aug 2009
Going offtopic, but put new engines on the 150/2s, disc brakes, air-con, selaed windows and quality 2+2 seating along with a new universal loo and you'd have a very nice unit to use on rural routes for years to come, maybe helping free up 153s for reformation back to 155s.
Need to sort out those rattling doors though!
Old Hill Bank
6 Mar 2010
Kidderminster
Nice idea but I'd bet there would be another 100+ things you would have to do to make them compliant to the standards that may apply when you do it (dissapears tearing hair out!!)
ps is it me or are the Perkins engined DMUs quieter than the Cummins ones?
bronzeonion
1 Apr 2009
West London
Why disk brakes? Good at slowing down from high speeds but theyre not as sharp as treads at low speeds
150001
24 Jul 2011
That sounds a good plan with the 150/2s; again slightly off topic but I've always believed the 150s needed a SWT 455 refurbishment as they looked brand new and very smart when refurbed.
Beveridges
8 Sep 2010
BLACKPOOL
150s just need better silencers, the noise levels are tremendous!
They already have large silencers - even tho they don't sound like it.
TDK
19 Apr 2008
Crewe
If you did that you would have a 158
AndyLandy
30 Oct 2011
Southampton, UK
Nobody's replaced the doors though, nor are there regional service facilities or the higher top speed :P
It's not far off it though. By the time you've invested in all those changes suggested, you might as well have bought some new trains.
Beveridges
8 Sep 2010
BLACKPOOL
To be honest though, I like their sound, throaty and powerful.
As far as modern units are concerned I think the best sounding one is the TPE Class 185.
Nowhere near as loud as a 150!! But the noise they do make sounds far more throaty when full power is applied.
Not like full power is applied often on a 185. They are up to line speed in no time and they are much more powerful than they need to be for the trans pennine routes.
A 150 has full power applied nearly all the time! On some journeys they are in notch 7 all the time until it's time to brake for a station! One reason why the noise levels are so tremendous.
ed1971
14 Jan 2009
Wigan
Yes, some Class 158s were built with Perkins 2006-TWH engines as were all the Class 165 and 166s. They are quieter. A Perkins unit was even fitted to 142084 in 1991 as an experiment when a replacement engine for the obsolete Leyland TL11 was being sought.
Class 150/1s do have a slightly different interior sound to the 150/2s. The former emit a loud howling sound throughout the interiors. I have read before that the two sub classes have around 83 differences between them.
4 Sep 2009
East Anglia
To my ears the /2s sound very different to the /1s, especially from inside. I'll use two Youtube clips I've found as examples.
The /1s tend to make a whining sound when revving up, like this:
http://youtu.be/H6fNNq-4-6A?t=1m45s
Whereas the /2s tend to have a constant wailing over the top, which changes pitch depending on the throttle position:
http://youtu.be/j5nRg6hc6sQ?t=39s
Personally I love the sound of 150s, definitely preferred to the constant vibrating/rattling/buzzing on a 172!
Class172
Quizmaster
20 Mar 2011
West Country
I like the 172s sound very much (one of my favourite modern sounds) as its so distinctive with the audible gear changes — sometimes it even manages to sound like an EMU!
150001
24 Jul 2011
I agree! Excellent smooth units, well built and I rarely feel/see any vibration or rattling issues.
anthony263
19 Aug 2008
South Wales
my freind who was with me when I visited Wolverhampton last tuesday made the comment that the 172's remind him of Southern's class 377 electrostars.
I had 172212 and 172341 last tuesday and both were pretty quiet especially compared to other dmu's as well as being very good accelerating.
