Mikey C
- Joined
- 11 Feb 2013
- Messages
- 8,292
The 143/144 were built using components from the Alexander P-type bus body.
https://www.flickr.com/photos/8050359@N07/5691430306
That thing makes the Pacers look quite attractive
what about the structural soundness of Pacers...? nothing ever seems to be said about trains structurally deteriorating, apart from body corrosion. the only exception I can think of is when 142-073's chassis cracked and ATW withdrew it and then TfW repaired (welded...?) it and recomissioned it.Which is why I mentioned structural soundness in my initial post in the subject. Bu definition this would rule out the worst of them i.e. the 108s, those with asbestos, the 104s which were rather rusty.
apparently aluminium doesn't rust but does corrode. Vivarail are reusing 40 year old aluminium bodies on the D-Trains.The early 158s have issues also. The truth is that the structural life of aluminium for rail passenger vehicles is an unknown. The class 158 will be the real test as they were the first.
That was an issue in the aftermath of the Winsford collision where the bodyshells of the rearmost unit separated from their chassis. IIRC a modification was made which lowered the chances of this happening.what about the structural soundness of Pacers...? nothing ever seems to be said about trains structurally deteriorating, apart from body corrosion. the only exception I can think of is when 142-073's chassis cracked and ATW withdrew it and then TfW repaired (welded...?) it and recomissioned it.
weren't (aren't) the bodies just tie-wrapped (or whatever it's called) to the chassies...? i was referring more to rot than seperation!That was an issue in the aftermath of the Winsford collision where the bodyshells of the rearmost unit separated from their chassis. IIRC a modification was made which lowered the chances of this happening.
I think that this photo shows a complete lack of aluminium because of the rust showing therefore all is steel.That page for the 142s also says that the body structure was "Aluminium Alloy (bus body sections) on steel frame". I was under the impression that the panels on the Leyland National were galvanised steel, and that the 142 more or less used standard parts with some extra components to provide the extra width.
The PEP family all had aluminium bodies long before the 158.
Plus London Underground stock before then. The A stock operating out to Amersham operated mainly in the open as well
Yes. That's the one. I couldn't think of the type at the time. I knew the 143 and 144 were also based on a bus type being built at the time.The 143/144 were built using components from the Alexander P-type bus body.
Which components, out of interest?The 143/144 were built using components from the Alexander P-type bus body.
